White 9000 Resto
15 years 3 weeks ago #40519 by geoffb
Replied by geoffb on topic Re: White 9000 Resto
By the way if someone want the diffs they are 5.2 with I believe Leyland hubs
Geoffb
15 years 3 weeks ago #40520 by Swishy
Replied by Swishy on topic Re: White 9000 Resto
Wot Can Eye say
WotSayU
[ch9787]
15 years 2 weeks ago #40521 by geoffb
A bit more removed
just waiting for the rails to be clean before the task of reassembling starts. ( By the way Swishy where did you get the picture of my sister)
15 years 2 weeks ago - 15 years 2 weeks ago #40522 by Stew70
Replied by Stew70 on topic Re: White 9000 Resto
G'day Geoff. Things are movin now hey? Whats the plan, are you keeping the same paint color on chassis or changing?
Stew.
Last edit: 15 years 2 weeks ago by Stew70.
15 years 2 weeks ago #40523 by
Geoff - The 25mm difference in wheelbase from one side to the other could be due to a number of factors. Accident at some time, would be high on the list .. diagonally twisted chassis .. broken centre bolt in one of the front or rear springs .. inaccurately drilled spring perch mounts .. even a bent axle housing.
One thing's for sure, 25mm difference in WB, sure would make her crab-walk up the highway.
All good chassis men measure the chassis for horizontal twist .. check for rail straightness, both in the horizontal and vertical planes .. check diagonal measurement to ensure no diagonal twist .. check crossmembers for cracks, displacement, twist, loose or missing rivets .. and so on, etc, etc ..
Cheers - Ron.
15 years 2 weeks ago #40524 by
ive gotcha now " 25mm difference on wheelbase" , you mean from one side to the other! that's a bit, does the spread on the bogie measure the same both sides? could be like onetrack says "broken centre-bolt" maybe a rail, need to take some serious measurements before you begin to set up that new rear end mate! might have been handy to find out what's going on before disassembly, but you will work it out
"onetrack" : All good chassis men measure the chassis for horizontal twist .. check for rail straightness, both in the horizontal and vertical planes .. check diagonal measurement to ensure no diagonal twist .. check crossmembers for cracks, displacement, twist, loose or missing rivets .. and so on, etc, etc ..
"i agree with that statement"
cheers Adam
15 years 2 weeks ago #40525 by geoffb
It was actually the cut off that the components are coming from had that. On pulling the diffs there appears to be no centre bolt on the main support beam on the front diff
15 years 2 weeks ago #40526 by
roger that geoff! well that's easy then mate....carry on ;)
Cheers Adam
15 years 1 week ago #40527 by
How's it going Geoff? Any updates?
-Stu
15 years 1 week ago #40528 by geoffb
Well the update is the sandblaster finally turned up and cleaned chassis rails from air tank back (As some are aware that this a step by step tidy up not a complete tear down tidy up) so the ferret can now see the burrow. Had a look at the rails and decided that we do not require all those holes and will fill them. Went to local hardware shop to get hole fill in and they didn't have the correct size >:( So the next job is weld and clean and re-prime. Gives plenty of tome to think and have figured that if you take the left rail off the cut off now stripped turn it over and backwards that you can actually use it as a template (that will get some thinking :-X) So hopefully in the next week we can get the hole maker out and make holes.
Time to create page: 0.323 seconds
