INT 6 Cyl 281 motor question
- Capitano1300
12 years 6 months ago - 12 years 6 months ago #64327
by Capitano1300
INT 6 Cyl 281 motor question was created by Capitano1300
Hi there guys hope everyone is well! Im after various parts for my 1971 International CM1300 metrovan, to start with Im after a carburetter, to fit the 6 cylinder 281 International motor? Also what size/type of battery would I need?
:)Thanking you in advance
Last edit: 12 years 6 months ago by Capitano1300.
12 years 6 months ago - 12 years 6 months ago #64328
Replied by on topic Re: INT 6 Cyl 281 motor question
Capitano1300 - The carburettor you're after is a Stromberg BXUV-3, with a Stromberg code number of 32-3302, and a P/No of 2375019.
The basic BXUV-3 is a common carburettor, fitted to many Holdens & Bedfords .. but each model (code number) of the BXUV-3 is altered slightly with different components to suit the application.
The Stromberg carburettor model you require was also fitted to the C1100, C1200, C1500, C1510, C1600, D1110, D1210, D1310, D1510, and the D1610.
The models it was fitted to, first appeared in 1966 and the last model produced, using this BXUV-3 code number, was in 1978.
You will need a battery of V8 capacity, that has a CCA of around 700 amps, equivalent to something like an N70Z or N70ZZ (Z or ZZ indicates the terminal positioning).
You need to check the dimensions of your battery box, the positioning of the terminals, and go to your local battery supplier armed with the info, the truck model and your tape.
Most battery manufacturers no longer recognise or list the C or D series International trucks of the 60's and 70's .. and to make things worse, they have all branched out into using their own codes numbers and model numbers, so it's impossible to compare different batteries.
Make sure the battery comes with a good long commercial vehicle battery warranty. If they don't want to back it with a decent warranty, they haven't got much faith in their batteries.
2 years should be a minimum warranty period. My personal favourite brand is Century/Yuasa, I once had a Yuasa battery that lasted in excess of 9 years before it gave up.
Cheers - Ron.
Cheers - Ron.
- Capitano1300
12 years 6 months ago #64329
by Capitano1300
Replied by Capitano1300 on topic Re: INT 6 Cyl 281 motor question
onetrack - WOW!!!!! mate you are an absolute legend, I very much appreciate you taking the time out to help me with that info, you are like an encyclopedia! hahaha
I hear what your saying about the batteries also, I will go armed with as much info as possible this week.
Thanks again mate for taking an interest in my project
cheers
Jamie
cheers
Jamie
12 years 6 months ago #64330
....yeah capitano..........i wish i was as brainy as him!!
ps as always onetrack...good work.
cheers
cheers
12 years 6 months ago #64331
by aussie l plate
Replied by aussie l plate on topic Re: INT 6 Cyl 281 motor question
would this van also run a positive earth????? i think the trucks did
12 years 6 months ago #64332
I'm happy to stand corrected on this
But i think that,
If it's got a generator, it's positive earth..
If its got an alternator it's negative earth....
Replied by hayseed on topic Re: INT 6 Cyl 281 motor question
But i think that,
12 years 6 months ago #64333
by Chocs
Replied by Chocs on topic Re: INT 6 Cyl 281 motor question
dunno about that one 'Seed,.....
Got an ol banga here with a genny,,shes NEG earth...
Chocs
Chocs
12 years 6 months ago #64334
The old man had a AB160, fairly certain it was positive earth.
but like I said willing to stand corrected
12 years 6 months ago #64335
by Bugly
I too stand to be corrected.
Replied by Bugly on topic Re: INT 6 Cyl 281 motor question
I think 'seed is right, but a genny may have since had a polarity change from positive to negative earth. An alternator would be negative earth regardless.I'm happy to stand corrected on thiswould this van also run a positive earth????? i think the trucks did
But i think that,
12 years 6 months ago #64336
by aussie l plate
the AB 150 we used to have on the farm, was a positive earth, was fitted with a genarator
Time to create page: 0.508 seconds
