- Thank you received: 1760
Commer Superpoise Restoration
13 years 4 months ago #73550
Replied by mammoth on topic Re: Commer Superpoise Restoration
Yor will have seen reference to types of petrol on other posts. These old trucks used very low octane fuel as that was all that was available in the period. Since global warming became a threat to civilisation as we know it our governments have decided that by burning diesel to power tractors and make nitrogen to grow corn we will be saved by using ethanol as fuel. Your old motor will burn ethanol BUT ethanol sucks water out of the atmosphere and then condenses in the tank and elsewhere which in turn lossens the water soluble dirt that got stuck over the last 40 years. It also wrecks seals etc made pre 1980 (or something like that) so avoid E10 like it was poison.
13 years 2 months ago - 13 years 2 months ago #73551
by JBran
Replied by JBran on topic Re: Commer Superpoise Restoration
Here are some random piccy's of what I have been doing...
Trying to change the oil filter...didn't go well
Pulled it out of the shed it was in (dirt floor
) cleaned it out and relocated it to another shed with a concrete floor
This is what happened to both of the front tyres in the process
Putting the starter switch back in...
Pressure washing the engine bay
Sunset...
In the shed...
My crappy photoshopping skills on display. Won't look completely like this, but at least the colour, lights, wheels, mirrors and 'Bullbar' (if that's what it could be called)
Nearly drove her out of the shed the other day...those front tyres let me down...engine don't have enough power to push...
Sunset...
In the shed...
Last edit: 13 years 2 months ago by JBran.
12 years 11 months ago #73552
by JBran
More random pics of stuff thats been happenin
Dash dials-pretty good condition for 57 years of age. Had to get the temp gauge fixed though
Took a fair bit of leverage to get some of those rear nuts undone
From underneath the rear of the tray after the rears had been taken off
Left side with rear hubs and brakes taken off
Left side with hubs, brakes and fuel tank taken off
12 years 11 months ago #73553
Replied by on topic Re: Commer Superpoise Restoration
JBran..you look like you're having more fun than a priest at a nuns convention
...keep up all the good work
12 years 11 months ago #73554
Replied by bigcam on topic Re: Commer Superpoise Restoration
JB, looking good mate. You've probobly already done it, but it looks like it could do with a couple more blocks under the chassis to be on the safe side, even if you just stack the wheels on top of each other and slide them under the chassis in front of the rear axle with a bit of timber on to top them for a bit of peace of mind.
12 years 11 months ago #73555
little trick to undo tight wheel nuts (and having that block is a good set up too) - While levering down on the spanner have a helper wack the end of the socket with a sledge.
Time to create page: 0.256 seconds
