rust removal from inside fuel tank
13 years 9 months ago #73912
Replied by on topic Re: rust removal from inside fuel tank
Best way I found is cut the bottom off it if they are that rusty then you can clean it easy I have done to a few tanks and it works just fine. dave
13 years 9 months ago #73913
by Hotmagic
Replied by Hotmagic on topic Re: rust removal from inside fuel tank
Depending on how bad it is, check out KBS
www.kbs-coatings.com.au/
they have a tank repair kit, that looks interesting, havnt had the need to test it out myself so I dont know if its as good as it looks.
13 years 9 months ago #73914
by tonym
If you can't afford a Dodge
Replied by tonym on topic Re: rust removal from inside fuel tank
Definitely go the POR15 fuel tank treatment kit.
I used it and it worked great.
First step is a cleaner, then a phosphoric acid cleaner and zinc phosphate sealer and the final step is another sealer.
Costs a bit but it also seals up any pin holes.
13 years 9 months ago #73915
Tony ,
is POR 15 the one you see where they connect the tank to a cement mixer in the adds . Dave ???
13 years 9 months ago #73916
by tonym
13 years 9 months ago #73917
Thanks Tony very interesting I see they have POR 15 plastic (bakerlite) steering wheel repair kit and at a good price . dave
13 years 9 months ago #73918
by tonym
I have to get a steering wheel repair kit eventually.
Their Metal Ready and Marine Clean products are excellent. Have used them alot, highly recommended.
13 years 9 months ago #73919
Tony
I have had 2 steering wheels repaired using same sort stuff as POR 15 and have turn out very well you wouldnt know they had been repaired . Dave
13 years 8 months ago #73920
by haig
Replied by haig on topic Re: rust removal from inside fuel tank
Hi, Would suggest that you make sure you get fuel tank really clean. I have now had two fuel tanks in different projects which I thought where clean but held me up along the road. Clogged fuel filters high fuel consumption and parked up along side of road. >
Replaced one with a stainless steel tank, and the other I used Red Kote on which worked well
. Have used fishing sinkers to knock rust off count them going in and out lol.
Time to create page: 0.163 seconds
