Sealing Roof Lights
17 years 1 month ago #7984
Sealing Roof Lights was created by
Hello To All,
I was just wondering if anyone had any hints or tips of effective ways to seal the roof clearance lights and air horns on the roof of my truck from water?
I have bought new clearance lights and air horns, which all come with rubber gaskets to install with. Should I give them a good coat of silicone or sealant? The reason I ask is when I origianally stripped the cab back, everywhere on the roof where there was a CB antenna, sun visor, clearance light, or horn it was very rusty and water had been getting in.
Or is this something that is unavoidable? Especially on an ACCO!
Regards
Stuart
Regards
Stuart
17 years 1 month ago #7985
by podge66
Replied by podge66 on topic Re: Sealing Roof Lights
:)Go and buy some 3m drip check and put that around the holes and screws. Silicon or slastitic is acided and eats into the metal causing rust. drip check is also good in the gutters when you rip the old corking compond out. You can paint over it also.
podge
podge
17 years 1 month ago #7986
Replied by on topic Re: Sealing Roof Lights
Great!, Thanks for that, I'll be off to get some tomorrow!
17 years 1 month ago #7987
Stewy
GuddayM8
Silicone cums in mainly 2 types
the proper names escapes me now
but one is for windows n showerscreens n very asidedik (spel it any way U like)
this one eats into metal
the other GP type of silicone is ok
but wot we have now moved onto is the black Eurathane th@ they use to fit windscreens to cars n trucks with
the problem everybody haz with silicone or the eurathane is it clings to u're finger n makes drag marks when tryn to smooth off
But B Tween U n me n nobody else
a little secret we have discovered if U use detergent n water dip u're finger in it n drag th@ across the gunk for a perfect finish
as it wont stik to water n detergent on your finger
to prevent rust in ACCO cab U might need to fully seal under the lights as any water sitn between cab n light will surely B a trap to water n cause rust
jist my 2 cents worth of dribble GST included
[ch9787]
Replied by Swishy on topic Re: Sealing Roof Lights
Stewy
GuddayM8
[ch9787]
17 years 1 month ago #7988
Replied by Cunning Stunt on topic Re: Sealing Roof Lights
Hey stuart
Podge and the Swishster are right in what they say. Some silastics are acidic and you can pick it if they smell like vinegar. Go to Bunnings and buy some SIKAFLEX in a tube. It isn't acidic and sticks really well but don't get any on your hands as it is a bugger to get off.
17 years 1 month ago #7989
Thanks for the help guys.
I never knew that ordinary Silicon was such a no-no!
17 years 1 month ago #7990
by kennymopar2
Replied by kennymopar2 on topic Re: Sealing Roof Lights
i 2nd sikaflex ..that sh@t is good although a little more expensive than ordinary silicone
17 years 1 month ago #7991
by Rookie
Replied by Rookie on topic Re: Sealing Roof Lights
Not a huge fan of sikaflex for your purpose, and I use to fit windscreens for a living. If you want to remove the lights in the future you will be cutting them off. Rust will form under sikaflex if you have bare metal. VL commodore front screens are a classic example.
I think where a lot of the problem starts is where bare metal is exposed drilling into the roof. The exposed metal should be primed and painted before the light is fitted. I still think the rubber gasket is all you need, but if you want to seal the hole, I would be using butal mastic or 3M drip check.
17 years 4 weeks ago #7992
by Eddy
Replied by Eddy on topic Re: Sealing Roof Lights
I 2nd wot rookie said.
Butyl Mastic is the go IMHO.
And don't overtighten the fitting. That'll deform the gasket.
17 years 4 weeks ago #7993
Replied by Sarge on topic Re: Sealing Roof Lights
Me too... I am a mastic man (there is a song about that... mastic mastic man... village people???)
there is another product I used once apon a time on our caravan that was the bees knees called VALIANT but I think it was just a brushable mastic for the long roof joints etc....
Butaylmastic (spell it yourself) is the go, does not set or go off like Silly-Con.
Sarge :-X
Sarge :-X
Time to create page: 0.338 seconds
