Big red Dodge
12 years 10 months ago #101850 by Hardtopman
Big red Dodge was created by Hardtopman
After chasing one for a while luck has found me and this big old lady is home safe. Have known about this truck for a while and have tried buying it a few times. I payed a bit of money for it but she all works as she should. Brakes work but need a bit of love as one rear wheel cyl leaks a bit and the vacuum light stays on so there is a leak some where and needed brake fluid before she was drivin. Also the clutch master was a bit sticky from sitting and took a bit of coxing to bleed up to get a pedal. Power steering works great and don't leak and the engine runs like a dream no smoke or noise. Carby needs a bit of a fiddle. Thermostat seams like is stuck as she got a bit hot on the way home and the top hose was sucked in, got up to about 180 on the gauge on the 20kay drive home.
Is build number 107 out of 110 A1075AV model trucks built from 1960-62
12 years 10 months ago #101851 by IHScout
Replied by IHScout on topic Re: Big red Dodge
Great find there hardtopman. I reckon its always worth pying a bit extra for something you can drive home and start having fun with, without needing a full resto.
Hope this the start of a regular longer topic from you as you take us through your tinkering ;)
Dennis
12 years 10 months ago #101852 by 600Dodge
Replied by 600Dodge on topic Re: Big red Dodge
Very nice. Were all of those 1075s single drive? Is that 361 the 6.6:1 compression engine?
12 years 10 months ago - 12 years 10 months ago #101853 by Hardtopman
Replied by Hardtopman on topic Re: Big red Dodge
Not sure but i would say it would be. Same 183bhp as the AT4 361 Not sure about the single/bogie drive but i think anything with a lazy axle or bogie drive would have been added later. I have a 1960-62 Dodge parts book and there is only single drive eaton axles listed.
Last edit: 12 years 10 months ago by Hardtopman.
12 years 10 months ago #101854 by Mrsmackpaul
Replied by Mrsmackpaul on topic Re: Big red Dodge
I reckon it's always worth paying a bit extra for somthing you realy want then it dosn't hurt so bad well Hardtopman
12 years 10 months ago #101855 by 700GMRR
Replied by 700GMRR on topic Re: Big red Dodge
Nice one Hardtopman, is this the one from the maddington truck auction we went to a few years ago.
you plan on doing a bit of wheat carting or bobcat work with your new rocket?
12 years 10 months ago #101856 by 600Dodge
I thought I had seen this one before.
12 years 10 months ago - 12 years 10 months ago #101857 by Hardtopman
Yer thats the one, it had moved around a few times since then.
A few more from today after i swapped the rear inner left wheel that was flat. Took it down the local shops and put some petrol in it, will get used to that with a V8 petrol :D
12 years 10 months ago #101858 by kenny-mopar
Replied by kenny-mopar on topic Re: Big red Dodge
what sort of road speed is she geared for ?
12 years 10 months ago #101859 by Hardtopman
Has had the governor takin off so maybe it would spin a bit harder than 3600 rpm. Maybe it would hit 55-60 mph. No speedo but ive run it up to about 40mph
Time to create page: 0.148 seconds
