Big red Dodge
12 years 11 months ago #101860 by 600Dodge
Replied by 600Dodge on topic Re: Big red Dodge
Ah Mundijong, I went through there the other day when I got lost going to Malaga, looks like a nice place, A bloke I know from Kalgoorlie lives out that way now I think.
12 years 11 months ago #101861 by atkipete
Replied by atkipete on topic Re: Big red Dodge
Great Dodge, that rust around the mounting points for the front guards seems to be a common problem.
Does yours have the cross steering ie steering box on RHS, just behind the front axle and steering the LH wheel, which then steers the RH wheel via a drag link.
12 years 11 months ago #101862 by tim
Replied by tim on topic Re: Big red Dodge
Hardtopman, well bought mate. Just looking at your last photo in the first lot, not often that you see a generator these days. Was just looking at the genny & noticed how close the fan blades appear to be to the genny pulley, are they that close or is it just an optical illusion. Good to be able to drive it whilst you work on it, helps keep up the interest. All the best, cheers Tim ;)
12 years 11 months ago #101863 by ute253
Replied by ute253 on topic Re: Big red Dodge
what a tuff lookin truck that is!!!!!!
You may be well aquainted with the petrol bowsers with that V8 petrol, but the sound, the sound!!!!!!!!!!!!!!!
Music to ones ears :) :)
Good luck with it all
Diamond T P3320 x 2&&Studebaker US6 6x6&&HQ GTS Coupe&&HQ ute&&HG ut
12 years 11 months ago - 12 years 11 months ago #101864 by Eddy
Replied by Eddy on topic Re: Big red Dodge
nice pickup!
V8 petrol ain't that bad really! ... little bit of attention to detail in the tuning department goes a long way.
ditch the 8.25 tyres and upsize to 9.00 .... just like having overdrive 8-)
Last edit: 12 years 11 months ago by Eddy.
12 years 11 months ago #101865 by kenny-mopar
Replied by kenny-mopar on topic Re: Big red Dodge
being a early 361 has it got the 2bbl holley ? by the way i want one of those trucks now ;)
12 years 11 months ago - 12 years 11 months ago #101866 by Hardtopman
Replied by Hardtopman on topic Re: Big red Dodge
No has the normal set up for the steering with the box mounted at the front R/H rail and drag link back to axle. And then the ram pushes from one side of the front axle to the steering arm on the other side. The set up you are thinking was used on the early 48-53 trucks that were out of Canada.
Last edit: 12 years 11 months ago by Hardtopman.
12 years 11 months ago #101867 by Hardtopman
No it got the BBD 2 barrel Carter same as the early AT4 361's.
12 years 11 months ago #101868 by clarkie383
Replied by clarkie383 on topic Re: Big red Dodge
Nice score Bruce,will need a bigger shed before you start building the new one.
12 years 9 months ago - 12 years 9 months ago #101869 by Hardtopman
Working the old girl
And some junk i have scored that i have to go get when it cools down
At4 is a 690 that i will grab the poly and 5 speed and then the power giant has had a perkins 354 put in it.
4WD Austin would be worth saving i reckon, story i was told it was ex army, brought in low miles after some conflict and used as fire engines
Last edit: 12 years 9 months ago by Hardtopman.
Time to create page: 0.322 seconds
