Getting more top end speed from a Morris LC5?
12 years 8 months ago #111082 by LincolnLC5
Hi, Any ideas/methods for getting another 5 - 10mph from a 1957 LC5 (i.e. freeway/highway speeds)? My truck is a sweety. Just 26,000 miles ever (genuine!) A low gear screamer (like all LC5's) - but just a bit more legs would make her spot on.
12 years 8 months ago #111083 by mammoth
Reality is that the only way to get more speed is to put a sail up on a windy day. Jokes aside, there is no point trying to gear up as she just doesn't have the power to pull a higher gear. (more speed = more rolling resistance and more importantly, wind resistance cubed) As they say, smell the flowers and enjoy the ride.
12 years 8 months ago #111084 by
Not sure were you are but you could talk to someone like www.transgearsdiffs.com.au/contact.html and they might be able to make you up a new crown wheel and pinion set $$$$$ and more $$$$$ but as mamoth said will it have the go to pull them or will you be needing to change down gears at the site of every ant hill or a bit of head wind.
Drive it as it was built slow and steady.
Trevor
12 years 8 months ago #111085 by Swishy
Elsie 5
Costly xercise to get new cogs cut
May B cheaper to wheel under nuther diff from a Known source of the correct ratio
Depend n on u're capabilties
U could grab sum xtra rims to suit ure truck n weld 20" 22.5" or 17.5 inch rimsn go grab sum ol preluvd tyres n try th@ as an experiment
Not sure if rear body/tray etc would need 2 B modified o removed etc
But to do this U need 2 B fully aware of wot can happen
12 years 8 months ago - 12 years 8 months ago #111086 by
...would it be a thought to fit an overdrive gearbox (with suitable adaptation) from a late model jigger... and have the minor improvement in speed for the easy running...and then not using the overdrive for the more strenuous stuff :-/ :-/
12 years 8 months ago - 12 years 8 months ago #111087 by Chocs
An alternative?
Im not sure on the size and capablities etc of this vehicle.
Could a 'joey' box be fitted? Room permitting of course.
Keep the original shafts etc in tact, should you need it back to 'original' one day
9 times out of ten it will run around in direct, should the conditions be favourable, slip it into overdrive.
chocs 8-)
12 years 8 months ago #111088 by
An alternative?
chocs 8-)
Choc's why you not suggest this to me for the 27, could do with a bit more speed. ;D ;D ;D
Trevor
12 years 8 months ago #111089 by Chocs
Forget the joey box SpeedTrev...
I think if i had that ol banga in the yard..
It would get a small block in it and a few disc brakes..
We'd get some speed in the speedtruck then ol mate :D
chocs 8-)
12 years 8 months ago - 12 years 8 months ago #111090 by
:) :) :) :) :) food for thought
12 years 8 months ago #111091 by Bugly
Don't lissen to him Trev ... next he'll be wantin doors and a roof chop! :D
Time to create page: 0.284 seconds
