2 stroke emergency stops???
12 years 7 months ago #118053
Replied by Swishy on topic Re: 2 stroke emergency stops???
GM also produced a 51 series (valveless)
2 cyl & 4 cyl (now very collectable)
not forget n the series represents the cubic capacity of each cyl .....51cubic inches ,53,71,92,149
But
WaddaEyeKno
But
WaddaEyeKno
12 years 7 months ago #118054
OK
Sum Jimmyless Crummins owner Iz Q:? the 51 series
Detroit Diesel Engines
Detroit diesel produced the first supercharged two cycle diesel. The series 51 was the "TRUE" 2 Stroke; G.M. needed a new engine to take the 51's place...
The series 53 was the engine that took the 51's place. The 53's were G.M.'s first diesel with valves, inline and V configuration were available (inline: 2, 3, 4) (6V, 8V). The 8V53's had a timing gear train problem. The gear train was to light for the valve train load, this was common for some 6V53's. G.M needed a bigger engine with more power.
The series 71 fixed the 53's timing gear problem and let Detroit make bigger engines with more power and torque. Series 71 came in many configurations (inline: 1, 2, 3, 4, 6) (6V, 8V, 12V, 16V, 24V)...
Series 92 was the new replacement truck engine, 71's were squeezed to the limit. The 92's were cheeper to run and more reliable. Came in 6, 8, 12, 16,24V configuration
Series 149's were made after W.W II for mining and other heavy uses in construction and marine. Came in 8, 12, 16,20V configuration
Detroit Diesel Series 51
The Detroit Diesel Series 51 was a two-stroke diesel engine. Two versions were produced, an inline two-cylinder and an inline four-cylinder model. It was a simplified version of the Series 53 that did not have exhaust valves. This was accomplished by using scavenger ports for both intake and exhaust, similar to a two-cycle gasoline engine. Since the Diesel fuel is injected just before top dead center virtually no unburnt fuel is expelled in the exhaust unlike a two-cycle gasoline engine. The elimination of exhaust valves reduced the complexity and weight of the engine. This allowed the engine to be more portable and easier to service. Its uses include: Marine propulsion, generators, pumps and other industrial uses. It was never used for automotive purposes.
www.angelfire.com/oz/detroitdiesel/page2.html
Clikity...ClikCLikClik
- Thank you received: 7881
12 years 7 months ago #118055
Replied by Mrsmackpaul on topic Re: 2 stroke emergency stops???
wasnt there a 110 series or am I just dreaming ?
12 years 7 months ago #118056
by Chocs
Replied by Chocs on topic Re: 2 stroke emergency stops???
Not bad info there Swishman..
Without interupting the thread too badly..
Do you have some operation schematic diagrams?
Particularly, the blower flap configuration..
thank you
chocs
thank you
chocs
12 years 7 months ago #118057
by werkhorse
Yeah mate it was the 6-110 mainly for industrial specs I believe
Replied by werkhorse on topic Re: 2 stroke emergency stops???
12 years 7 months ago #118058
maybe this might help Bobsboy
hmm,
no, but I'll take your word for it.
More research (by me) needed.
Sounds like one of those cockamamie british ideas.
2 stroke not 2 cycle, ports, turbo's and valves. ???
Why don't we just perfect the blowing up part?
(and give them something entertaining to do until their all gone?)
-b
:-X
12 years 7 months ago - 12 years 7 months ago #118059
by Bobsboy
Mucking about on the edge
Replied by Bobsboy on topic Re: 2 stroke emergency stops???
Thank you mrsmackpaul.
I think I got it now.
I am intrigued and facinated again.
It's not just one of those funky, obsolete loopy pommy engineering concepts.
(Now the Knocker Lads will be after my blood.)
A combined exhaust/ intake/ compression stroke,
The exhaust valve and injector working in PRECISELY TIMED UNISON)
The blower blasts air through the exposed inlet port and the open cylender (exhaust valve open),
The piston blocks the port, the exhaust valve closes, the piston continues its up ward journey, the remaining air in the cylender is compressed, the injector shoots its mixture, and hey presto magic, the whole thing explodes, the piston is sent to the bottom of the cylender in a mighty, hurculean burst of Detroit Power ! !
where the whole process begins anew.
Brilliant,
I wants one again.
-b
P.S.
Through out this thread, I was always wondering how long it would take Mr Swishy to bite.
:-X
idstbc olddon (the only thing wrong?)
ta
Brilliant,
I wants one again.
-b
P.S.
ta
Last edit: 12 years 7 months ago by Bobsboy.
12 years 7 months ago #118060
by olddon
Replied by olddon on topic Re: 2 stroke emergency stops???
The only thing wrong there,is that it is a blower,not a turbo.
12 years 7 months ago #118061
BobzBoy
Az eye've sed
There B 2 types of ppl in thiz world
Thaose th@ have screeemers
n Those, they wish they did
OlDon
a late invention for the 2 stroke screeemers twaz to have a blower & a turbo
yes not forget n the 110 series straight 6...the Victorian Railways had many
n 4 those th@ like/can reed ....bit more info...jist clik on theze 2
www.maritime.org/fleetsub/diesel/chap3.htm
www.tugboatenthusiastsociety.org/pages/t...l-modern-dd71-01.htm
BobzBoy
Az eye've sed
OlDon
12 years 7 months ago #118062
by Chocs
And Swish, is it true that most of these engines are preserved on the bottom of various waterways, anchoring Cray Pots, Bouys and other Marine Stuctures?
chocs
chocs
Time to create page: 0.291 seconds
