Updated 28th July.
Welcome, Guest
TOPIC:
Yanky Iron Fix II 02 Jan 2022 09:04 #230085
  • Morris
  • Thank you received: 955
Are those last two real trucks or are they carefully posed model/toys?
Yanky Iron Fix II 19 Feb 2022 08:31 #232217
  • Mrsmackpaul
  • Mrsmackpaul's Avatar
  • Thank you received: 2624
Freshly flogged from Facelessbook, looks like the original camel trailers
The predecessor to the Kenworth K100 series cab-over-engine models was this truck known as a CSE or cab-surrounding-engine. These were developed to meet restrictive overall length regulations.
#Kenworth #ThrowbackThursday #K100
The following user(s) said Thank You: PaulFH, Southbound
Yanky Iron Fix II 04 Mar 2022 19:22 #232604
  • Mrsmackpaul
A bit wider than the average vehicle, the Kenworth Model 963 is an off-road truck used mainly in oil field work to move rigs and equipment. But sometimes you just have to get across town!
The following user(s) said Thank You: cobbadog, Inter- Action, PaulFH, asw120, Southbound, Brocky45, oliver1950
Yanky Iron Fix II 04 Mar 2022 21:11 #232611
  • Dave_64
  • Dave_64's Avatar
  • Thank you received: 748
That 963, now all we need to see is some Dick knock up a styleside ute "tub" and go hooning around the streets!
Yanky Iron Fix II 05 Mar 2022 00:58 #232620
  • V8Ian
  • Away
  • Thank you received: 430
Beer run. ;)
The following user(s) said Thank You: Inter- Action
Yanky Iron Fix II 05 Mar 2022 03:53 #232621
  • Mrsmackpaul
Well some times you just need a beer I guess
Yanky Iron Fix II 05 Mar 2022 08:10 #232622
  • Swishy's Avatar Topic Author
  • Thank you received: 2610
Yanky Iron Fix II 05 Mar 2022 15:55 #232649
  • cobbadog
  • Thank you received: 1624
There sure is some impressive trucks in that video. I am partial to a Kamaz but with the politics being played out now I find them off putting. That Berliet from France was also impressive and I like how they used a Volvo truck to float it about the place. Then the big Kenworth. I thought to make a bigger truck you would need bigger components and for them to say they used components from other models was a shock. Are Clarke transmissions an option in Kenworths?
Yanky Iron Fix II 30 May 2022 21:32 #235561
  • Mrsmackpaul
Found myself a new ute, or maybe a new ute for Swishman thanks to Facelessbook
This is a rare Kenworth model W300 featuring the cab of a W900 and a cut-down hood on a shortened 4X4 chassis to serve as a utility truck for oil field and other off-road work.
The following user(s) said Thank You: cobbadog, Inter- Action, PaulFH, oliver1950
Yanky Iron Fix II 31 May 2022 20:32 #235589
  • Mrsmackpaul
I80 truck stop museum
The following user(s) said Thank You: cobbadog, PaulFH, oliver1950
Time to create page: 0.405 seconds
