- Thank you received: 1337
Yanky Iron Fix II
3 years 5 months ago #238854
by V8Ian
Replied by V8Ian on topic Yanky Iron Fix II
- Thank you received: 7962
3 years 5 months ago #238855
Replied by Mrsmackpaul on topic Yanky Iron Fix II
So what brand of motor is that, Hall Scott ?
3 years 5 months ago #238857
by V8Ian
Brocky or Swishy may have some idea.
Dunno Paul, I just found and posted with all the information supplied.So what brand of motor is that, Hall Scott ?
3 years 5 months ago #238872
Replied by Dave_64 on topic Yanky Iron Fix II
Just doing a bit of research in an old motor manual, and on the web, seems the above vehicle COULD be a one-off 1951 KW made to a special order.
"Curbside Classics" has a little bit on it, firstly KW had to extend the front by a foot, 12", to accomodate the engine.
It was a marine derived, twin six,bolted together to give a total of 1090 cu-in, 1900 ft-lb torque and could be run up to 600 hp OR up to 900 hp in supercharged form, but I tend to think that would be in marine format.
Biggest problem at the time was none of the usual transmission manufacturers could supply an off the shelf transmission/ clutch.
Doesnt say how they got around that issue.
IF it is the same truck, which I reckon it is, it was a one-off built to pull a tanker.
Finding a bit more, seems that although fuel consumption would have been cruel, given the low grade fuels available at the time, it was more a reliability issue why it wasnt a raging success!
Hall-Scott had a superb name in big displacement marine and stationary engines right up until the mid to late 50's until being taken over byHercules.
Not a bad read if you want to chase it up a bit.
Hall-Scott had been supplying large six cylinder petrol motors for quie a few manufacturers, including Fageol ( later Peterbilt), KW, Autocar etc.
Seems they were pitched in direct competition ( in petrol engines) against makes like Continental, Wausheka, Hercules to mention a few.
BTW, that particular vehicle MAY have been a chain drive bogie, which would have been a single diff!
Imagine the size it would have been!
Dave_64
Dave_64
- Thank you received: 3427
3 years 1 month ago #241877
by overlander
Replied by overlander on topic Yanky Iron Fix II
The following user(s) said Thank You: 180wannabe, Inter-Action, PaulFH, V8Ian, wee-allis, xspanrman, oliver1950
3 years 1 month ago #242136
by overlander
The following user(s) said Thank You: Inter-Action, Mrsmackpaul, PaulFH, wee-allis, xspanrman, oliver1950
- Thank you received: 313
3 years 1 month ago #242138
by Inter-Action
Replied by Inter-Action on topic Yanky Iron Fix II
Wow! Long buggers. Long bonnets. Anyone got any idea of what's under the bonnets?
- Thank you received: 814
3 years 1 month ago #242147
by 77louie400
A lot more space than under the bonnet of my LNT louie
Replied by 77louie400 on topic Yanky Iron Fix II
3 years 1 month ago #242155
by overlander
Inter-action. I'd say they use what engines that have been available to the Australian transport industry. Different length laws allows manufacturers to produce models like that I have posted. COE models are well out of favour. later on there will be photos of a Freightliner with a 16v71T engine and yeah- that truck has a long bonnet of note. Pete
3 years 1 month ago #242159
Just as a bit of an aside to the above, Youtube shows Quite a few 12V92 T's and the odd 16v71, in both cab over and conventionals.
Time to create page: 0.309 seconds
