Gvm vs gcm? Atkinson
11 years 10 months ago #145405 by Chocs
Replied by Chocs on topic Re: Gvm vs gcm? Atkinson
Q.
Has the vehicle been registered in Australia before?
Does it have the engine and chassis numbers to match the previous registration?
Is it the original plate.?
Do the engine and or chassis numbers match that original plate.?
Do you have the previous registration papers.?
Proof of ownership from the previous owner?
If the better part of all that is yes.
I would make an appointment to speak with someone at vicroads.
Front up with all the information you have, I am sure there will be a solution, even if you were issued with a new Id plate and numbers to suit etc.
They are generally pritty good to deal with, if all the info can be provided.
Hope that helps?
chocs 8-)
11 years 10 months ago #145406 by Dig a ditch
G'day
You blokes r a very helpfull bunch!
Ill answer the questions, yes all the numbers match both on the plate and previous rego papers from Vic. I'm trying to register it in nsw.
The bloke doing the pink slip has done some invistigation with the local Rta officers. They came to the conclusion that its probably had a cab change at some stage and the plate has been lost. Interesting though that they both said the brass plate could not have been on the chassis due to the year of the truck!
So I've got a few bits of paper to sign and some details to give and I can get it registered. The next thing is the stuff I have to fix! Ill start another thread for that.
No school like the old school!
11 years 10 months ago #145407 by
Replied by on topic Re: Gvm vs gcm? Atkinson
...just exactly what year is the truck Dig...by at least the rego papers?
11 years 10 months ago - 11 years 10 months ago #145408 by Chocs
Very good, hope it all turns out ok.
Always a trap if the tags are on the rear of the passengers door.
Even with a door swap, someone could quite innocently overlook the tags and they are gone forever..
international were right into door tags.
From memory yours is a mk3.? Probably should have had the chassis plate and cab tags.
Will you ask the rta for a new vin tag, so as you will be right next time?
chocs 8-)
11 years 10 months ago - 11 years 10 months ago #145409 by
...it appears the early plastic Atkinsons had very little in the way of any I.D's...
...Dig, if you would like to quote some numbers off the big chassis plate, we can decipher at least a rough year of the Chassis...
11 years 9 months ago #145410 by Dig a ditch
G'day
Truck is supposed to be a 1975,
Chassis number is fc22498
Engine is 8vf009880877040
See what ya make of that!
11 years 9 months ago #145411 by
....that ch/no has got me stumped Digga .. probably is a fair dinkum '75 model ...thanks and cheers
11 years 9 months ago #145412 by Chocs
fc22498
Full cab
22 ton
4 drive wheels
9 gears
8 cylinder.
Wasn't too hard..
chocs 8-)
11 years 9 months ago #145413 by Dig a ditch
G'day
So does that mean it was once a sleeper or does full cab mean day cab?
Mines presently a day cab!
Anyway of telling if the year is correct?
11 years 9 months ago #145414 by Chocs
Well ditch..
I think that my chassis number designations, are about as accurate as my front end identification..
Sometimes.. They don't mean anything, just a number
chocs 8-)
Time to create page: 0.273 seconds
