Hoo U Gunna Call
6 years 11 months ago #182624
Replied by Swishy on topic Hoo U Gunna Call
Morry M80
Swiss Cheeze or fillet of fish
Mrs
Neck is gunna B like a camel
flop it down to hop on ....................... jist like your one
Thanx fir u're interest guys
Mrs
6 years 10 months ago #183463
The following user(s) said Thank You: PaulFH, Diggerdave
- Thank you received: 839
6 years 10 months ago #183464
by BillyP
I used to be a truck driver,
on a good day i can remember
Replied by BillyP on topic Hoo U Gunna Call
.Not a bad effort there ..........looks mickey mouse.............
.........................Billy.........................
- Thank you received: 4696
6 years 10 months ago #183473
Replied by Mrsmackpaul on topic Hoo U Gunna Call
Swish man and the rest of BSG crew you have done impressive job
Or at least Im really impressed by this work
Thanks for the pics Swishy
6 years 9 months ago #184494
Mrs
Thanx fir them kind wordz
A gooseneck iz born
Wide wall clad n
the KW 1/2 Truck gets a run (tight access)
A gooseneck iz born
Wide wall clad n
6 years 9 months ago #184497
by rex
Replied by rex on topic Hoo U Gunna Call
Swishy mate
I can't help watching what you are building and if you recall I have made a couple of comments. Call it interference but on each occasion my remarks / questions have nothing to do with the Kenworth / Volvo banter.
The outer beams are open and therefore subject to collecting both moisture and dirt. While there may have been some treatment to preserve the steel before fabrication some will now be bare due to the welding, our experience is where there is an opportunity for both moisture and dirt to accumulate you will get serious rust. We have found the best protection is smelly Fish oil and when you apply it flood the thing with it let it soak in then drain off the surplus.
Rex
Rex
6 years 9 months ago #184499
ReX
Thanx for your input
we have had a few changes in the make n of the expando
the main beams are hollo as we gunna make it extendable 6.5m+ closed --- 12m open to suit 40 container etc
then add a nother axle of 8 on airbag
runnin the 2x8 dolly we may get just under 70t P/Load
the hard will B get n the G/Neck links correct so it will fold n B the correct deck height
6 years 9 months ago #184500
Swish man I was gunna ask you about this as I wanna change the geometry on mine to lower the rear of the top deck so I can fit other things like scrapers etc on there easier
Swishy wrote: ReX
6 years 9 months ago #184502
Mrs
Gudday m8
just thro a cupla twigz down so U can waltz up to the neck with the tyres
Also U can cut the last cupla X members in neck n make m bolt in if th@ can help
Gudday m8
6 years 8 months ago #185256
ReX
M80
all taken on board bout rust
we have had xperience with rust from many moons ago
we have also noticed any cavity in the frame where no air circulates can cause rust
so we try inlimin8 any place where stale air is
also now all equipment is stored under roof in B F Shed
Now well underway wiff the goosey neck LOL
M80
Time to create page: 0.630 seconds
