- Thank you received: 8
Trailer identification
5 years 1 month ago #199449
by cro
Trailer identification was created by cro
5 years 1 month ago #199450
by cro
Replied by cro on topic Trailer identification
Numbers on the ID plate 36958 next line down 44800 next line down 28 - 21.
Build date 26-1-72
Stamped on rail directly under plate
36958J752
& under that
T753
Wondering if any info on this trailer as have been told it was a spread axle bogie at the beginning.
Cro
Build date 26-1-72
36958J752
& under that
T753
Cro
5 years 1 month ago #199451
by cro
Sorry Freighter Pacemaker
5 years 1 month ago #199454
Replied by geoffb on topic Trailer identification
If its the same as a couple i know opposite side to plate at rear on outside rear rail
5 years 1 month ago #199459
Replied by hayseed on topic Trailer identification
Contact Maxitrans, (makers of Freighter trailers) they have a very good archive section. they should be able to give you the build sheet on It...
- Thank you received: 4705
5 years 1 month ago #199462
Replied by Mrsmackpaul on topic Trailer identification
I would have tjought pacemaker trailers were to late for spread trailers
But I could be wrong
5 years 1 month ago #199498
by cro
Mrs, A local from these parts made the suggestion that, "that trailer was a spread bogie when new" just thought that someone on hear may have the build sheets for Freighter Aus. I cannot see any modification but who knows. Will chase up Seeds suggestion.
Trailer has been fitted with tubeless tyres which stick out.
Can I modify or change spacers & lugs to make rims/tyres shallower or are there other tricks to make the tubeless fit or do we need to go back to tube rims & tyres
5 years 1 month ago #199503
You can get different spacers, just as long as the wedges dont bottom out
And some tubeless rims have different offsets
Check if tyres stick out each side as there maybe badly worn rockers and spring hangers or maybe the axles arent located properly on the springs
Just some ideas to look at
5 years 1 month ago #199513
by PaulFH
Replied by PaulFH on topic Trailer identification
Also check trailer width. Earlier models, if it was a spread trailer, would be 8 Ft.
Newer units went to 2.5 Metres, or 8 Ft 2 1/2 Inch. If it was modified with later
axles, that would explain the wheels protruding, about 1 1/4 Inches each side.
If so, matter of finding rims and / or spacers to bring track width in that much.
Might be a tall order, as inner rim is located on spider ramp so a narrow spacer
would bring the outer rim in too far for the wedges to clamp correctly.
Not sure if the earlier spiders would interchange to give you a result.
Might be easier to fit some spray fringes or similar to disguise the projections.
I laughed at the time, but livestock carriers widened their trailers and crates to
the new width. Extra 2 cows on a 41 Ft 10 Inch trailer. Good luck, Paul.
5 years 1 month ago #199514
Replied by asw120 on topic Trailer identification
Would the first two numbers be the weights, collapsed and spread respectively?
Time to create page: 0.528 seconds
