- Thank you received: 10
Mack air starter trouble
4 years 11 months ago #200165
by Timmsy
Mack air starter trouble was created by Timmsy
Have E6 with air starter trouble
Is connected up to get a shot of diesel, turn the key and air goes through the starter, (have very good pressure in starter tank), but the air starter doesn't seem to engage, and crank the motor.
Have no leaks, can turn the key 3-4 times before air pressure drops below 120. Use air compressor to re charge.
Has been working well for years, truck has sat for a month.
Any advice/tricks to get the starter motor to engage? or do I have to take it off the truck?
4 years 11 months ago #200168
Replied by Swishy on topic Mack air starter trouble
Timmsy
gudday m8
<1> dosse the air by pass the vanes in a whooosh
<2> dose the air starter turn ovr but wont turn the big donk ovr
if <1> the vanes could B dry ... try addn sum oil in the inlet where the diesel hose goes ....... a thin weak oil..... there should B a mist of diesel sprayed near the exhaust of the air starter
normally a off color spray on the bottom of block n sump stain
If <2> the last time the beast twaz started the centrifical force has thrown the bendix cog out to end of travel & it has jammed.... easy remedy take starter out ..... slide cog up n down
apply oil to stop the cog stik n
your Welcome
Next
gudday m8
your Welcome
Next
The following user(s) said Thank You: Timmsy
4 years 11 months ago #200171
by Timmsy
Replied by Timmsy on topic Mack air starter trouble
Will purchase some air tool oil and take off the diesel pipe, squirt it down there.
I think the Vanes are being bypassed, the air comes out in a big whoosh. No suggestion of air starter spinning,
I don't have a co pilot to turn the key, while I gaze and ponder at the problem.
Air tool oil will be first option. I'm guessing should let it soak/penetrate for a while?
4 years 11 months ago #200173
Replied by JOHN.K. on topic Mack air starter trouble
The vanes will be stuck in the rotor,and probably have to take off the endplate ,and free them with a small pointed tool................they stick pretty hard sometimes.
4 years 11 months ago #200174
If U got an "R' model ..... bottom of fire wall passenger side
the wires for the air stater go into dump valve
th@ can B operated from pushing a pen or simular up the guts to bypass the electrics ete..... Ideal wen got flat bettery
4 years 11 months ago #200176
by Timmsy
Its a R model, the fire wall collection of wires looks messy enough! I had the valve and wires replaced a few years ago and still looks good.
By taking off the end plate, do you mean take starter motor off truck and disassemble motor, or is this something can be done with starter motor in place.
I'm guessing its a heavy bugger to take off.
4 years 11 months ago #200177
look under the electric air valve n u'll C a 1/2" hole push up a pen to activate the air starter
B 4 U yank stater off give the thin oil ago with a few hits of air to start n do it a few times to free up the vanes .... May B
4 years 11 months ago #200178
by Timmsy
Will give the thin oil a go.
Thanks, will update progress.
- Thank you received: 4631
4 years 11 months ago #200182
Replied by Mrsmackpaul on topic Mack air starter trouble
I aint no expert
However a few things I would try are
1 pull the big air hose off the tank end and poor heaps of diesel down it, half a liter or more
Then try to start it
May need to try this a couple of times to fully lube the vanes etc and get the jigger going again
2 pull the starter off, it aint that heavy and I reckon its lighter than a Delco starter motor that would be there instead
Before you ripping it apart mark the end plates and also stator (the round bit inside the main casing)
Gotta make sure these all go back in the same orientation as they came out as this determibes the direction it spins
If you jigger this up the starter will spin and the bendix wont be thrown out
3 rebuild the starter, new veins seals etc and they really will swing the motor over then
And follow Swish mans advice on the starter solenoid, you should see the two 1/4 air lines going to a valve with 2 wires on it
Air lines maybe one green, one white
Time to create page: 0.610 seconds
