- Thank you received: 4
Np435 DODGE FRONT INPUT SEAL
4 years 9 months ago #201647
by anthony
Np435 DODGE FRONT INPUT SEAL was created by anthony
Hi Can anyone help with locating a front bearing retainer seal for a 23 spline Dodge np435 box locally please.Cheers Anthony
4 years 9 months ago #201648
Replied by cobbadog on topic Np435 DODGE FRONT INPUT SEAL
When I'm looking for bearings and seals for my Pommy made tractors I take them into the bearing shop all nice and clean so the counter jumper doesn't get a bit of dirt under his finger nail and they look for the number and if none are found then they get out the calipers and measure ID, OD and width, they have always found a substitute.
An example is the front wheel bearing on my D.B. Cropmaster. They used some real odd angled bearings originally and the guys then did the measurements and plonked a set of bearings on the counter exactly the same sizes but a different angle for the bearings which made no difference. So get them to think outside the square and go with the sizes for a replacement.
The following user(s) said Thank You: anthony
4 years 9 months ago #201651
Replied by Dave_64 on topic Np435 DODGE FRONT INPUT SEAL
Anthony. Those seals are available at just about any good bearing/seal shop. Easy to remove, just about punch them out with a wooden dowell and hammer. Unless it’s totally wrecked, take it into said shop and throw it on the counter. Replaced a couple recently myself, had no trouble getting them. Dave
4 years 9 months ago #201653
Meant to add, when you remove the input bearing housing to replace the seal, measure the thickness of the gaskets/shims between the housing and trans case facing. That’s how you set the preload on the input/ mainshaft. Dave
4 years 9 months ago #201654
by anthony
Replied by anthony on topic Np435 DODGE FRONT INPUT SEAL
Yes it's a tapered bearing and cone, correct the gasket determines the end float . I will remove seal and take it to the bearing joint here in Mulgrave on Monday. Cheers.
Time to create page: 0.413 seconds
