- Thank you received: 1735
International
4 years 5 months ago #203719
Replied by JOHN.K. on topic International
The PTO depends if the truck is a 1820 0r a 1840.......different boxes ,different PTOs ......but since its a tipper its got a hydraulic PTO,so just run your crane from a hydraulic motor.......the ASC has likely got a mechanical F&R pto for the winch,unless you got one from a WW2 truck like a GMC or Studebaker,they are pretty hard to find.
4 years 5 months ago #203748
Replied by Swishy on topic International
Thanx for all the info
I will get sum numbers off the cogboxes to C wot PTO will fit
- Thank you received: 599
4 years 5 months ago #203753
Replied by 180wannabe on topic International
The 5 speed gearbox i made reference to earlier is AACO 182.
The PTO cover plate for the ACCO 1820 5 speed gbox has a different part number than for the 182, and as John K suggests, the 1840 is different again.
4 years 5 months ago #203756
Both have the std SAE 6 bolt pto openings ,but ptos are different.........the T35 box needs a helical gear takeoff ,the T54 box is straight tooth 6/8 pitch ,which is a pretty standard setup over most of the Fuller boxes.......even Roadrangers can take a smaller pto by using an adapter plate 8 bolt to 6............Im surprised that a truck backender can even get a lookin with Cranesafe and all that crap........why not get a BHB 10/12 ton,they sell for very little now,and are a really good crane for visibility all round.
4 years 5 months ago #203806
Replied by Lang on topic International
Swishy
Why don't you sell both the new and old inters you have and grab this. No stuffing around ready to go with modern hydraulics.
www.gumtree.com.au/s-ad/camperdown/truck...cco-truck/1231853583
4 years 5 months ago #203810
An old pole erector /borer...less the borer........not much use as a yard crane.........for the same money ,there are any number of 10/12ton BHBs for sale........cranesafe has just about killed any older crane,as the inspections cost more than they are worth...........the whole idea of it,to make you buy a new crane.
4 years 5 months ago #203814
Replied by cobbadog on topic International
Same goes for Hiab style cranes, they too have a life span before having to be rebuilt professionally and then re tested with the new tag fitted.
4 years 5 months ago #203823
by Bluey60
Replied by Bluey60 on topic International
I’m with Lang seems not bad value 12k for a truck and dog
Bluey
Bluey
4 years 5 months ago #203825
Replied by Morris on topic International
I don't know about the truck but I think the dog is not worth much except for eating scraps from your plate!
- Thank you received: 839
4 years 5 months ago #203832
by BillyP
That's a good one Bluey …/….yeah . I like that. !!!!!!!!!!!!!...………..
…………………….Billy...…………………...
I used to be a truck driver,
on a good day i can remember
Replied by BillyP on topic International
.Bluey60 wrote: I’m with Lang seems not bad value 12k for a truck and dog
Bluey
Time to create page: 0.525 seconds
