- Thank you received: 1739
International
4 years 5 months ago #203881
Replied by JOHN.K. on topic International
Phil Kitchen picked up one of the new big Chinese tractors for the importer,tried to pull it down on the tilt tray tray with the hydraulic winch I set up for him,the tractor snapped in half......he was blaming me for the fiasco.
4 years 5 months ago #203883
Replied by asw120 on topic International
I snapped my little (Allis B sized) Chinese tractor in half. It wasn't hard...
4 years 5 months ago #203885
Two for the price of one.
4 years 5 months ago #203889
by Bluey60
Replied by Bluey60 on topic International
Swishy
Have you pulled the pto off the old inter fiat chance if it’s got straight cut teeth it would fit and do the job
Cheers Bluey
Cheers Bluey
4 years 5 months ago #203899
Replied by Swishy on topic International
Bluey m80
we have removed the F&R PTO from the old ASC Inter n they B helicall cut teeth
jist wait n on a few contacts info
The ol ASC Inter has already got a few interested 4 wen we pension her off but not B4 the AACO crane B up n runn n
the ASC cab has dents n mistameaners on every panel n the only part th@ dun make a noise iz the horn
- Thank you received: 1174
4 years 5 months ago #203902
by Southbound
Replied by Southbound on topic International
...and the only thing that works in the cab is the driver! LOL
4 years 5 months ago #204294
SthBound
RE: and the only thing that works in the cab is the driver! LOL
have bin known to do a bit n put in ........................ occaisionally
OK next
No PTO with Forward n reverse available without fully importing one n go see the bank manager 1st LOL
think n n dreem n
take the ol 4 speed cog box with the correct PTO outa the ol ASC 160 yard crane to replace the 5 speed in the AACO that is Perkins powered
if it dun fit n marry upto the perkadyne bell housing
iz it just a case of making a adapter plate to get most the holes ligned up??
Thanx in advance
OK next
think n n dreem n
Thanx in advance
4 years 5 months ago - 4 years 5 months ago #204322
Im thinking you will end up with a hydraulic drive..........no problem with finding a hyd pump for a T35 box.....the Edbro is best for running a motor,but it needs to be in good condition......if you are lucky,the bell housing for the 5 speed will also be drilled for a four speed......some of the early ones were.
Last edit: 4 years 5 months ago by JOHN.K..
4 years 4 months ago #205025
OK
we saused out a forward n reverse PTO (UP n DOWN)
bit more todo the hook-boom-jib goes up n down
jist az pland
jist az pland
Time to create page: 0.471 seconds
