- Thank you received: 1735
What engines and, or gearboxes are being swapped into Austin K2 or K4 trucks
- charlie chapman
- Thank you received: 4696
The reason I ask is I believe you only need a joey box if you are still pplaning on pulling loads about, if you are planing on running around almost empty why not just get a 1.5-1 or 1.75-1 gear box new, there are plenty avaliable for industrial purposes and for all different power ratings
I think he wants an overdrive joey box. I am sure the old gearbox is more than low enough for his purposes.
Everyone to his own but I can't see the value in all that work on an Austin with all the other constraints of low power, very average brakes trying to make a silk purse out of a sows ear. I think Charlie would be better with a full repower and matching box as discussed above.
Charlie
A joey box (the most popular light ones are Brown-Lippe - "Browny") just goes under the chassis with a short shaft from the gearbox and a shortened tail shaft out the back.
JOHN.K. wrote: There isnt much point gearing up a 90hp motor ,you will probably end up going slower ....If you have a K2 ,the original diff ration is 5.85 ,and with 7.50x20 tyres ,this will tax the power of the motor at any revs.....I know from driving a Ford blitz with 12.00x20 tyres ,you can do 70mph on the flat ,but the slightest rise or headwind ,you just lose revs and power .....obviously answer is a Roadranger ,dunno if anyone has put one in a Blitz.....probably have ,I know a guy with a 13 speed in a 1300 inter ute........Anyhoo ,my point is 5.85 is plenty high ratio for an Austin truck
13 speed in a 1300 Inter. An exercise in futility?
I have heard that fitting the Austin coach diff, makes for a better speed for long runs, a bit less wine.
regs
Rupert
- charlie chapman
I was told the coach was better, But i cannot find that information.
austin diff ratios3 ton petrol 5.8-1 (78G 1007)
3 TON DIESEL 4.71-1 (78G 1008)
2 speed, 5.83-1,8.11-1, (7H 8537,)
note Austins were built under lic, by Nissan, Alloy head and other bits.
may help
regs
Rupert
