- Thank you received: 66
AC tap on alternator for tacho
- Rattail 1927
3 years 11 months ago #209813
by Rattail 1927
AC tap on alternator for tacho was created by Rattail 1927
So when I got the Acco I started buying some stuff and I bought a 80 amp unit made for a Isuzu npr with a vacuum pump as the forty year old asmatic vaccum system needs some help more than likely filling the two tanks ,
When I got it I didn’t know that the expensive tacho I bought needs a ac tap to work, and of course it doesn’t have the tap , question:- I know there’s 3 wires come from the stator to be rectified, is there a certain wire and is it possible to do myself.
- Thank you received: 546
3 years 11 months ago - 3 years 11 months ago #209855
Replied by Blackduck59 on topic AC tap on alternator for tacho
I thought this had been hashed out earlier.
Think you can tie into any of the 3 wires before the diode block, there is a bunch online about this.
Last edit: 3 years 11 months ago by Blackduck59.
- Rattail 1927
3 years 11 months ago - 3 years 11 months ago #209894
by Rattail 1927
Replied by Rattail 1927 on topic AC tap on alternator for tacho
Thanks Steve I haven’t seen anything else, having said that I cannot remember anything. I’ll check out , thanks Jim
Last edit: 3 years 11 months ago by Rattail 1927.
3 years 11 months ago #209899
by allan
Replied by allan on topic AC tap on alternator for tacho
On this very forum a few months back:
www.hcvc.com.au/forum/truck_Chat/18593-m...ho-alternator-driven
Might be something in there that helps
- Thank you received: 22
3 years 11 months ago #209942
by invested energy
Replied by invested energy on topic AC tap on alternator for tacho
Alternators can have two different winding connections and maybe 3 different rectifier arrangements, but tachos aren't usually very fussy on the actual waveform, so making a connection isn't hard.
Depending on how it's built, you'll probably need to remove the vac pump carefully, then separate the housings, taking the stator with the rear one. Try not to damage the windings.
Once it's cleaved in half, undo the little nuts or screws holding the rectifier plates in the housing. Be very careful not to lose any insulators/washers.
Find where the windings are connected to the rectifier... usually a series of three (or 4) decent sized soldered joints.
You need to solder a tail onto one of these and lead it carefully out of the alternator for your tacho.
Don't use supacheap shit wire, these things get pretty warm. Ideally you want some nice flexible wire with woven high temp sleeve (like the tail on a H3 spotlight globe) or use some heatshrink.
Just make sure it can't rub through, tie it with cable ties or some silicone where it comes out of the housing but don't block the vent holes too much.
You need a heavy soldering iron. 40watts won't cut it unless you're very good at using it.
Ideally you need the joint scraped bright and clean, wrap a couple laps of your signal wire around it, then with your iron hot and fresh puddle of solder on the face, apply heat and a little more solder to the joint. You only want it there for a few moments, enough to melt them together but not enough to make it run and drip... because drips into the stator can be a nightmare... and too much heat will see solder wick inside the wire that you need to remain flexible. (that's why solder is illegal on aeroplane wiring)
Hope that helps.
Hope that helps.
The following user(s) said Thank You: cobbadog, Rattail 1927
- Rattail 1927
3 years 11 months ago - 3 years 11 months ago #210198
by Rattail 1927
Wow it’s a bit of a job not sure if I am up for the job , actually I have a old alternator off a barina that I can get the feel of the job . thanks very much Jim
Time to create page: 0.419 seconds
