- Thank you received: 1735
Real world Acco fuel economy
3 years 10 months ago #211537
Replied by JOHN.K. on topic Real world Acco fuel economy
Front wheel drive .......from the factory ,the upper swivel bearing is a bronze piece ,the lower is a tapered roller .......the bronze bit is dear ,so often it will have taper rollers top and bottom........this can produce the choppy pattern ......another thing is the condition of the axle joint unis ,and also the support bushes in the axle spindle ....You can stop all the front rotation by removing the drive flanges ,and replacing them with plain plates (or Selectro FW Hubs ),or even just turning the drive flanges spline out........If the tailshaft is left attached ,the front will just rotate slowly on the drag in the transfer case ,and hopefully keep the steering pivot bearings lubed enough......Or you can take out the front tailshaft ,and nothing bad will happen ,just the upper steering bearing may need a bit of lube.
- Rattail 1927
- Thank you received: 66
3 years 10 months ago #211545
by Rattail 1927
Replied by Rattail 1927 on topic Real world Acco fuel economy
Ok thanks John I didn't know if I was opening up another can of worms , I'll do the tyres first with everything else left in then I'll do the jack shaft one at a time... I'll check if the shafts have sections to eliminate one more thing.
- Rattail 1927
3 years 10 months ago - 3 years 10 months ago #211582
by Rattail 1927
Well I better accreditation away , I've slipped up and got a "x" against my name..... tyre pressure is usually ( if someone knows please share ) my front tyre pressure were 20 and 38 ...... back ones were 60psi down to 15 psi ...... hmmm I'll get a slap on the hand for that, first written warning .... I'm maybe thinking over inflated tyres are not the cause of the problem, I'll still swap them tyres around and even put air in them about 80-85 psi , never going to have any weight so i ll do that all around and see what other mysterious noises come to bear.......
Last edit: 3 years 10 months ago by Rattail 1927.
- Rattail 1927
3 years 10 months ago #211608
by Rattail 1927
Well I probably should have saved my money for the Acco but I bought some Hume highway " bling " .... chrome gauge covers for the T-line feeling left over in the corner for a couple of weeks, only starting it yesterday to keep the batteries charged , I've often wondered if starting the engine for 5-10 minutes and know more as I read somewhere that to much idling actually washes away the oil of the ball , might stick on the charger once every so often but I will still need a driving fix ....
- Thank you received: 546
3 years 10 months ago #211609
Replied by Blackduck59 on topic Real world Acco fuel economy
A small Solar panel keeps they topped up, no need to worry about 240V and rain. May need 2 for 24V or dual controllers with 1 panel.
The following user(s) said Thank You: cobbadog, Rattail 1927
3 years 10 months ago #211610
^^^ I have a small Solar panel on both My Forklift & Front end Loader. They work well..
Replied by hayseed on topic Real world Acco fuel economy
Blackduck59 wrote: A small Solar panel keeps they topped up, no need to worry about 240V and rain. May need 2 for 24V or dual controllers with 1 panel.
- Rattail 1927
3 years 10 months ago #211611
by Rattail 1927
Thanks Steve, it's 3 12v batteries in parallel, please excuse my ignorance, what do you mean by controllers ?
- Rattail 1927
3 years 10 months ago #211612
by Rattail 1927
Hi hay seed , how much , where did get it and is it water proof thanks jim
3 years 10 months ago #211614
No eBay APP ID and/or Cert ID defined in Kunena configuration
Mate I've got something similar to this..
Rattail 1927 wrote: Hi hay seed , how much , where did get it and is it water proof thanks jim
- Thank you received: 4696
3 years 10 months ago #211616
Replied by Mrsmackpaul on topic Real world Acco fuel economy
Silvan boom spray people have 12 volt solar chargers like seed has shown
Had one for many years, very handy for the dozer once the pilot motor is removed and direct electric start is used as they have no alternator or generator
Just hook them up and they keep the batteries topped up
Time to create page: 0.548 seconds
