- Thank you received: 4
INTERNATIONAL 345V8 IGNITION DWELL ANGLE
3 years 9 months ago #211979
by Abbuss
INTERNATIONAL 345V8 IGNITION DWELL ANGLE was created by Abbuss
Hi guys I am doing a tuning check up my ACCO 510A 345V8 and if anyone knows the dwell angle for that engine it would be very appreciated.
Thanks in advance .Abbuss
3 years 9 months ago #211981
by Abbuss
Replied by Abbuss on topic INTERNATIONAL 345V8 IGNITION DWELL ANGLE
Thanks very much Lang we will see how she goes now.Abbuss
- Thank you received: 97
3 years 9 months ago #211988
by Dodgeydude
Replied by Dodgeydude on topic INTERNATIONAL 345V8 IGNITION DWELL ANGLE
Lang are you sure ignition timing is set at TDC?
3 years 9 months ago - 3 years 9 months ago #211990
Replied by Lang on topic INTERNATIONAL 345V8 IGNITION DWELL ANGLE
That is from a 1973 American International 1110 workshop manual.
There is a bit of discussion on the International site saying if the 345 is pushed to 3 deg BTDC they are prone to overheat before any detonation is evident. Like all discussions there are people for and against.
Here is a bloke showing how to time a 345. He suggests maximum 5 deg BTDC.
This bloke says 8 deg BTDC but it is on a Scout which consistently runs higher revs than a truck.
Last edit: 3 years 9 months ago by Lang.
3 years 9 months ago #211996
Replied by cobbadog on topic INTERNATIONAL 345V8 IGNITION DWELL ANGLE
When available I always set the points by dwell, just seems to be a better result.
- Rattail 1927
- Thank you received: 66
3 years 9 months ago - 3 years 9 months ago #212014
by Rattail 1927
Replied by Rattail 1927 on topic INTERNATIONAL 345V8 IGNITION DWELL ANGLE
Last edit: 3 years 9 months ago by Rattail 1927.
3 years 9 months ago #212062
Why on #8 Rattail? I've not heard of that before and on the car V8's I've had I always did it on #1 with no issues.
- Thank you received: 599
3 years 9 months ago #212067
Replied by 180wannabe on topic INTERNATIONAL 345V8 IGNITION DWELL ANGLE
Yep, Inter V8's are definitely timed on No.8
The following user(s) said Thank You: cobbadog, Rattail 1927
- Rattail 1927
3 years 9 months ago - 3 years 9 months ago #212075
by Rattail 1927
Yes the correct cylinder is number 8 not number 1 like every other V8 in the world , remember I have one too , I timed mine on number 8 the other day and it’s running perfect, Here is just one example below cobbacobbadog wrote: Why on #8 Rattail? I've not heard of that before and on the car V8's I've had I always did it on #1 with no issues.
Time to create page: 0.585 seconds
