When down in Ballarat today, returning a hydraulic ram that was sent in error, looking around their shop and found a box of 10 cutting pieces for the lathe, narrowest one only about 2-3mm wide (without actually measuring it). $58 for the box of ten, prolly Chinese, but I doubt I'll be cutting anything too hard.
Be interesting to see how they go on the poly.
Spun up a tapered bush on a 5/8" spindle, going like the proverbial house on fire, full revs, taking only small cuts and when I took it out of the chuck, came out as almost a liquid! (This was before I bought the new tool pieces). I saw on Youtube how a bloke got really good results with the blade of a Stanley knife fixed to a tool bit with a small home made clamp. Made it look easy, the machining part.
On another tack, kept going back to that bloke with the TK full tilt cab, assuming he either fitted another steering column off another tilt cab make? I have had shaft splines cut, when shortening 9" Ford diffs for a Jeep project years ago. Thought maybe about having the original inner steering shaft splined, then you have to match that with a female telescopic outer column so it will slide up and down.
I'd like to fit some sort of power steering eventually, so will have a look at a small full tilt cab Japper, most seem to have full power steering these days.
Dave_64
