Spent past cupla days ginning around with the cabin lockdown, as can be seen, ended up using a coupla tow balls and receivers, as suggested here. Needs a bit of fine tuning, either a light tap with a club or shake the cabin a bit so it settles square, no biggie. Removed the poly cushions I made, have to put them back in the lathe and take about the thickness of a couple of washers off them, either that or put a couple of packing washers under the tow ball mounts, six of one, half a dozen of the other. Bent up a bit of 3mm metal for the receivers to sit on, another plate to go inside the cabin, thereby using the rear of the actual cabin as a "sandwich".
Now its in the right position, tomorrow I'll just drill out the mounting holes and remount it with 1/2" hi-tensile bolts.
Got a few ideas on how to install a locking handle lever with a long piece of rod to actuate the tow ball lockers. Springs are way too heavy, so will scrounge around and locate some lighter ones.
Got someone in mind to attack the rust in the cabin, really only sitting on the chassis at the four corners, made up a gantry in the shed, gets it up high enough to then lift off.
Thinking maybe of installing a 12volt boat winch back in the chassis, run a sheave block up a bit of a mast just behind the cabin and anchoring it onto that eye bolt shown in one of the snaps. Had originally intended standing a bit of channel iron upright on the near side rear of the cabin, run both the inlet and exhaust up there, or maybe just the inlet, let the exhaust point down towards the ground. Thoughts??
Cheers, Dave
