Vacuum trailer brakes
4 years 10 months ago - 4 years 10 months ago #217827 by projectinter
Removing the trailer brakes off inter 1600.
Don’t know too much about it. If you see in the photo what I have circled is this all for trailer brakes or does is it used for truck brakes also? Basically just wanting to blank off the trailer brakes but not sure where to do it.
Thanks
Last edit: 4 years 10 months ago by Sarge.
4 years 10 months ago #217828 by myflint69
Replied by myflint69 on topic Vacuum trailer brakes
I've got a 1969 C1600 Inter, that canister is the filter for the vacuum part of the brake system for the truck.
Can't help you with the trailer part of the question, but , if it's fitted with a vacuum handpiece , perhaps work your way back to where it's plumbed into the system and blank it off , maybe.
Others on this forum will be able to share other thoughts on this.
1969 Mack R600.
1969 C1600 Inter.
1964 MF 35 Tractor.
The following user(s) said Thank You: projectinter
4 years 10 months ago #217829 by projectinter
Replied by projectinter on topic Vacuum trailer brakes
Thanks.
The red hose teed in before the canister goes to the vacuum brakes so I think that’s where i blank it. Just didn’t know what the canister was
4 years 10 months ago #217856 by myflint69
the truck itself relies on vacuum for the brakes aswell, I should have mentioned that in my previos post.
1969 Mack R600.
1969 C1600 Inter.
1964 MF 35 Tractor.
4 years 10 months ago - 4 years 10 months ago #217857 by Swishy
Replied by Swishy on topic Vacuum trailer brakes
WAG
the black hose is for truck ...red hose is for trailer
take the red hose off @ the 'T' with the black hose
do away with the 'T' n put in a straight barb connector to rejoin the black hose
if its dun wrong and it sux from atmosphere to engine will run like crap
BIDS2BC
EDIT ... found a pic
Last edit: 4 years 10 months ago by Swishy.
The following user(s) said Thank You: PaulFH, projectinter
4 years 10 months ago #217862 by V8Ian
Replied by V8Ian on topic Vacuum trailer brakes
Swishy and I would be the only blokes here, old enough to remember VoH trailer brakes and all I ever knew about them was that you had to help them by holding your hankie out of the window.
Probably why mums used to say wear clean undies and tak a clean hankie. Neither stayed that way for long. :S
4 years 10 months ago #217873 by JOHN.K.
Replied by JOHN.K. on topic Vacuum trailer brakes
I well recall Vac over Hyd trailer brakes ...Ive got a vacuum S cam trailer in the yard,the whole axle and brakes made by PBR.for Freighter........The proper vac/hyd PBR setup had a giant diaphragm chamber and a hyd cylinder that screwed into to it......but the catch with hyd trailer brakes is you could boil them off,and have nothing.
Time to create page: 0.289 seconds
