- Thank you received: 872
Lorries Brake Vacuum
- Thank you received: 4697
3 years 3 months ago #218152
That would be my guess
Replied by Mrsmackpaul on topic Lorries Brake Vacuum
overnite wrote: Into the booster?
3 years 2 months ago #218178
Replied by cobbadog on topic Lorries Brake Vacuum
I will take fly spray to kill the spiders under Lorry and crawl up under there to see where it goes. For a truck it must be lowered or Im very bloody round in the middle as I don't fit too well under there. Makes sense it goes to the booster but wouldn't the tanks supply the booster?
3 years 2 months ago #218182
Replied by asw120 on topic Lorries Brake Vacuum
Goes up the pushrod seal. PBR boosters are notorious for this. On those, it get sucked into the manifold and burns in the engine.
You may also find the booster just full of brake fluid in the vacuum chamber. BTDT.
3 years 2 months ago #218186
If it's diesel it will have a vacuum pump on the rear of the alternator
If it has sucked brake fluid in I'm fairly sure it will of returned into the sump thru the oil return line
It wouldn't be a huge drama as it's only a small amount
My little Isuzu does the same every now and then, I have noticed the pedal feels very un assisted last time I drove it, I must investigate this
3 years 2 months ago #218193
Paul, I was wondering where it would go in that case.
Curiosity satisfied.
Cheers, Jarrod.
Cheers, Jarrod.
3 years 2 months ago #218203
Yep Lorry is a diesel and has the vacuum pump on the back of the alternator but that end up there is bone dry so no fluid getting that high up.
The possibility of it getting behind the diaphragm in the booster/s is a possibility as they are mounted on the tanks and since I have not been in that area I cannot confirm if fluid is inside.
I think I will let sleeping dogs lie and see if more fluid disappears.
Time to create page: 0.557 seconds
