T34 gearbox into acco 1830a
3 years 1 month ago #219479
by AccoPhil
Replied by AccoPhil on topic T34 gearbox into acco 1830a
Yeah mine has a pivot point near the gearbox for selection , thinking I’d do away with all that and making something similar to sarges pic and modify for the angles
3 years 1 month ago #219487
Replied by Sarge on topic T34 gearbox into acco 1830a
my old shifter is a bit loose, I have replaced the pins and tidied up what I could, the worst wear is the pivot point under the shifter, a quick grab for 3rd will sometimes pop it out of the socket. It would be a pain to have to do that to tilt the cab..... that said, if i needed to tilt my cab on a regular basis, I would just make the top 3/4 s of the shaft screw into the bottom 1/4. so the join was about at floor level., and make the two speed switch detachable or the lead made long enough for it all to happen.
The following user(s) said Thank You: AccoPhil
- Thank you received: 599
3 years 1 month ago #219491
Replied by 180wannabe on topic T34 gearbox into acco 1830a
Keep in mind to maintain the same neutral position of the stick, so it doesn't foul when you tilt the cab.
3 years 4 weeks ago #219835
by AccoPhil
Hi mate , change of plans with the truck and the t34 box is up for sale, I paid $1500 for it but willing to let go for $1200 I’m in mackay QLD
3 years 4 weeks ago #219838
Ah ok, i'll send you a PM a bit later today/this evening. Thanks.
