- Thank you received: 407
Gearbox main shaft question
2 years 10 months ago - 2 years 10 months ago #222559
Gearbox main shaft question was created by jon_d
I've been working on the gearbox in the Bedford and have a question regarding play in the main shaft.
Long story - short. The gearbox is an Isuzu MLD6Q. (six speed overdrive - steel casing). The rear main and counter shaft bearings were rotating in the casing. The gap was minimal, (ie a 0.02mm feeler wouldn't fit). So I've removed the bearings and then glued with bearing retainer.
When every thing was reassembled, and the tail shaft flange attached. (the nut was tightened to 580 ft-lbs as per the WSM) I have noticed a detectable forward/backwards ( F-B ) play in the main shaft. The movement must be limited by the F-B travel in the roller bearings.
I don't know whether the movement was there prior to disassembly. I didn't detect it prior. However, it may not have been noticeable as the bearing was effectively a slip fit in the case and it was moving about anyway. (Now it's fixed - aka interference fit)
My question is; in gearboxes, is there normally a detectable (say 1--20 thou) F-B movement in the main shaft?..... I'm trying to determine if I haven't pressed (hammer and drift) the inner bearing race down on the shaft enough and hence, there is a gap in things along the shaft.
I'm thinking/hoping that now the outer race is glued/fixed, I'm just seeing the actual F-B movement in the race rollers and the hard stop as they rest up against the inner/outer race walls.
The work was done under the bus. Any more work might be limited to trying to push the inner rear race forward a whisker and then reassembling.
Thanks, any insights would be really helpful.
The bearing looks like this.
The inner race is at at the bottom and slides in - not easy to see the step in the race. The second ring is a thrust washer.
Jon
Jon
Last edit: 2 years 10 months ago by jon_d.
2 years 10 months ago #222562
by overnite
Replied by overnite on topic Gearbox main shaft question
To tighten a bearing in a worn housing, before you use bearing loctite or similar, do several centre punch marks in the bearing housing to tighten it up.
- Thank you received: 546
2 years 10 months ago #222570
Replied by Blackduck59 on topic Gearbox main shaft question
Roller bearings are not designed to carry thrust so I would guess a little float is normal.
2 years 10 months ago #222571
Replied by JOHN.K. on topic Gearbox main shaft question
Ive never seen a truck gearbox with a roller at the back of the mainshaft.....every on I ever worked on had a big ball bearing ,or even two like a roadranger ,to take the endload of the tailshaft moving ........However ,a well oiled roller can take considerable thrust,and a lot more load than a ball bearing.
2 years 10 months ago #222572
Replied by jon_d on topic Gearbox main shaft question
Thanks all,
I rang an old mate in SA and in QLD and both just said it's all ok with the end float. No problems. Pity the WSM didn't mention it.
In hindsight, I reckon I didn't feel it previously because the bearing was slipping in the case.
Overnite; Yes, centre punched all around the inside of the casing.
Hopefully all will be good, as it's going across across the Nullarbor in a few months. Thanks again.
2 years 10 months ago #222575
Outer race turning in the case is not a problem.......inner race turning on shaft will overheat the bearing......so you are good to go..
