Updated 28th July.
Welcome, Guest
TOPIC:
Dumbass question(again!) 30 Jun 2021 22:44 #222966
  • Dave_64
  • Thank you received: 463
Got an email back late this arvo, Donaldson cant even positively identify it, suggested I write to Paccar, yet they show a similar sort of flexible tube in of all things, a Bobcat instillation.
Dumbass question(again!) 01 Jul 2021 00:21 #222967
  • V8Ian
  • V8Ian's Avatar
  • Away
  • Thank you received: 222
Quite possibly it can't be sourced as a part, only as a component of a complete assembly.
I cannot buy the hose between the snorkel and airbox, for my car. I have to buy the airbox lid, for an inflated price.
Dumbass question(again!) 01 Jul 2021 03:42 #222968
  • Mrsmackpaul
  • Mrsmackpaul's Avatar
  • Thank you received: 1522
Sounds like a quick trip to the wreckers might be a plan, walk around and see if you can find something along the lines you are chasing
I would try truck wreckers, tractor wreckers, and those 4x4 wreckers and those jokers that wreck jap cars as well
Who knows wreckers might not even let you walk around yards any more ?
The following user(s) said Thank You: cobbadog, Dave_64
Dumbass question(again!) 01 Jul 2021 17:19 #222985
  • Dave_64
going back through some older postings, reckon this is one put up by roKWiz, clearly shows the part. You will note that the bottom of the air inlet tube still attached to the cab has been flared to receive the fixed rubber
Last edit: by Dave_64.
Dumbass question(again!) 01 Jul 2021 17:42 #222986
  • oliver1950
  • oliver1950's Avatar
  • Thank you received: 379
You can't have too many toys!
The following user(s) said Thank You: IHScout, Dave_64, roKWiz
Dumbass question(again!) 01 Jul 2021 18:15 #222988
  • Sarge :-X
  • Sarge  :-X's Avatar
  • Thank you received: 333
I reckon a flare on each end of an air intake pipe with a big o ring to take the presure. Those size o rings are in bunnings for plumbing fittings, you would need an olive on the lower section to hold and locate the O ring for the top section to sit on. No boot required.
Olivers bell and ball, but a rubber ball instead of steel.
Sarge B)
Last edit: by Sarge :-X.
Dumbass question(again!) 01 Jul 2021 18:43 #222989
  • Dave_64
Thanks Sarge, will investigate, sounds an easy way out. Cheers Dave
Dumbass question(again!) 02 Jul 2021 08:32 #223005
  • roKWiz
  • roKWiz's Avatar
  • Thank you received: 229
Hi Dave,
the little truck ones are more of an oval shape bellows which are adjustable through the clamps.
Heritage Stonemason
Last edit: by roKWiz.
Dumbass question(again!) 02 Jul 2021 15:46 #223013
  • cobbadog
  • cobbadog's Avatar
  • Thank you received: 1111
WOW, you got some arm pit hair growing on that one!
STUBBOURN B@ST@RD
The following user(s) said Thank You: roKWiz
Dumbass question(again!) 02 Jul 2021 19:22 #223017
  • Bluey60
  • Bluey60's Avatar
  • Thank you received: 131
Jeez Cobba I didn’t know it was armpit hair always thought it was from further down
