- Thank you received: 79
Oil Filter problem
2 years 9 months ago #223642
by cliffo
Oil Filter problem was created by cliffo
Did some work on Mack motor requiring removal of oil filter housing so fitted new filters. On startup oil pressure stayed at 30psi regardless of revs where normally 60psi at idle and 75psi with a few revs (cold). Took off Donaldson and replaced with same. Long story short as a last resort fitted new filters and all back to normal. Can anyone explain?
2 years 9 months ago #223645
by Kav
Replied by Kav on topic Oil Filter problem
What model Mack motor Cliffo?
2 years 9 months ago #223646
by cliffo
Replied by cliffo on topic Oil Filter problem
237 maxidyne
2 years 9 months ago #223656
Replied by cobbadog on topic Oil Filter problem
A bit of gasket flaked off and blocked the gallery?
- Thank you received: 4707
2 years 9 months ago #223657
Replied by Mrsmackpaul on topic Oil Filter problem
Developed a air lock ?
Is there a bypass valve in the filter housing, may have stuck open for some reason
2 years 9 months ago #223659
by Kav
I haven't worked on that part for years but I sort of remember two things which dropped the oil pressure. The first one was a blocked oil filter or the wrong filter which limited the flow and bypassed in the valve over the filters. The other thing was the valve which limits the oil to the piston coolers when it's idling. If it was to stick open, the oil pressure may be affected. Just a couple of suggestions. Kav.
Time to create page: 0.421 seconds
