- Thank you received: 49
UD exhaust brake
- wedgetail84
2 years 6 months ago #226223
by wedgetail84
UD exhaust brake was created by wedgetail84
Is it normal for a UD CWA45 to not have a micro switch on the accelerator pedal to cut out the exhaust brake? I’ve had a good look around the pedal and linkages but pretty sure it’s never had one. Was this common practice?
2 years 6 months ago #226225
by Brocky45
Replied by Brocky45 on topic UD exhaust brake
How new is it??? I would assume on these electronic engines it would be part of the "Fly by Wire" computer connection???
- wedgetail84
2 years 6 months ago #226228
by wedgetail84
Replied by wedgetail84 on topic UD exhaust brake
Its 1985 - not much electrickery going on!
2 years 6 months ago #226230
Replied by jon_d on topic UD exhaust brake
Being Japanese, (I reckon) there will be a circuit board that looks like a transistor radio, but smaller with not antenna coil or speaker tucked in the steering column somewhere. It will be sensing a few inputs. The brake is probably sensed from the same circuit as the lights which will be triggered from a pressure switch somewhere. Maybe even in the hydraulic line itself.
2 years 6 months ago #226232
Replied by JOHN.K. on topic UD exhaust brake
Switch may be on the pump?.....i do recall ,the cutout wouldnt work if the idle was set too high by the button in the cab.
2 years 6 months ago #226236
Replied by hayseed on topic UD exhaust brake
This may help you..
read-download-books.com/v6/preview/?pid=...a45_Parts_Manual.pdf
2 years 6 months ago #226252
by V8Ian
Replied by V8Ian on topic UD exhaust brake
I have vague memories of some Jap jiggers having a plunger or lockout of some description, preventing depression of the accelerator, when the exhaust was on.
2 years 6 months ago #226253
by V8Ian
I have vague memories of some Jap jiggers having a plunger or lockout of some description, preventing depression of the accelerator, when the exhaust brake was on.
- Thank you received: 4704
2 years 6 months ago #226265
I have me feeling you are right, or very close to been right, there was some small little Jap thingy I drove once that had something to stop your accelerator getting pushed all the way under certain conditions
I have me a feeling it was 22 seater bus and it was if the door never shut fully ?
May be wrong but it was something along those lines and I reckon it was a Toyota Coaster jobby
Replied by Mrsmackpaul on topic UD exhaust brake
2 years 6 months ago - 2 years 6 months ago #226268
by roKWiz
Having a few smaller Jap trucks myself, I can not say I've even seen something that stops you pressing down on the acc pedal. When you do that it just cancels the exhaust braking via a couple of switches, one on the clutch pedal, one on the acc pedal (both look similar to a stoplight switch)
Heritage Stonemason
Replied by roKWiz on topic UD exhaust brake
Heritage Stonemason
Last edit: 2 years 6 months ago by roKWiz.
