Volvo F7 gearbox airlines
2 years 6 months ago #226340
by Squiggles
Volvo F7 gearbox airlines was created by Squiggles
Does anyone have a diagram for all of the gearbox air hose connections for Volvo F7 (1981) with SR61 (overdrive) gearbox please ? Including those to gear lever high/low and overdrive controls
- Thank you received: 4696
2 years 6 months ago #226346
Replied by Mrsmackpaul on topic Volvo F7 gearbox airlines
Sorry, Im of no help, have tried a Mack - Volvo dealer, most are pretty helpful and will email you what ever you need
2 years 6 months ago - 2 years 6 months ago #226356
Replied by hayseed on topic Volvo F7 gearbox airlines
Welcome Squiggles. As Paul said Most Dealers are helpful.. !!
Plus I think Forum member mammoth has an F7. He should chime in in Due course I would Think..
Last edit: 2 years 6 months ago by hayseed.
2 years 6 months ago #226386
by werkhorse
Replied by werkhorse on topic Volvo F7 gearbox airlines
I have some older Volvo info and Manuals ... Might be able to find something in them if you can wait a day or two
The following user(s) said Thank You: Squiggles
2 years 6 months ago #226388
by Squiggles
Replied by Squiggles on topic Volvo F7 gearbox airlines
Hi, happy to receive any help. Much appreciated
2 years 6 months ago #226393
Replied by mammoth on topic Volvo F7 gearbox airlines
Not directly familiar with the F7 but the SR61 was fitted to the last of the F86 of which I have one. Range change is the usual wire control from gear stick to internal cylinder at rear of box and split was also wire control from engine hump (or dash on the 88 and between seats on N series)) to external air cylinder on right side of box . As it is pre-select there are interlocks with clutch etc. You will have an air line to the clutch servo and to top of gear box. Will have to have a look at splitter.
It was only with the later SR62 that splitter had switch on gear stick.
2 years 6 months ago #226398
by werkhorse
Out of luck sorry ....can't find any diagrams ..or even useful pictures in what have here
- Thank you received: 313
2 years 6 months ago #226399
by Inter-Action
Replied by Inter-Action on topic Volvo F7 gearbox airlines
Was that Volvo i advertised the same as yours. It will be in the for sales. 8 wheeler . Check it out . If it is the same i may be able to have a look for you. I don't know a lot about the truck but think it has the original gear - box. Let me know if i can help. Dave
2 years 6 months ago #226480
by Squiggles
Hi Inter-Action, yes it's an 8 wheeler. The one you advertised looks similar. Therefore if you could have a look on the air hosing of the one you advertised that would be great. Cheers
2 years 6 months ago #226491
by Inter-Action
What info do you need and will a couple of photos help. If that is not enough you can always buy this one for a spare?
Dave.
Dave.
Time to create page: 0.412 seconds
