- Thank you received: 49
Strange tyre wear - please help
2 years 1 month ago #233219
Replied by Swishy on topic Strange tyre wear - please help
Check distance from front wheel to rear wheel compare both sides of bus
also check toe in
Zero '0' to 1/16th inch toe in may B OK
also check toe in
2 years 1 month ago - 2 years 1 month ago #233224
Replied by hayseed on topic Strange tyre wear - please help
I second what Swishy Said.. Check your Toe in..
I'd also get the Tyres turned around on the Rims to even the wear up..!!
EDIT; Swapping Tyres from side to side would also Help even the wear up..
Last edit: 2 years 1 month ago by hayseed.
2 years 1 month ago #233228
Replied by Lang on topic Strange tyre wear - please help
Having wear on same side of both tyres does not seem a toe-in problem. At first glance it looks like some serious axle misalignment or bent chassis. I vote with Swishy also to do the front/back measurements. I vaguely remember bad camber on one side can produce similar tyre results, as well as any camber faults also effecting toe-in and castor measurements.
I would imagine if you let the wheel go it would always wander off to the the same side?
I am sure a truck alignment place would give you the answer in 10 minutes. At $500-800 for a pair of tyres a visit would seem a good investment. Never know it might be nicer to drive afterwards as well?
- Thank you received: 4707
2 years 1 month ago #233231
Replied by Mrsmackpaul on topic Strange tyre wear - please help
Yep what the others have suggested about measuring axle to axle
2 years 1 month ago #233232
by PaulFH
Replied by PaulFH on topic Strange tyre wear - please help
Agree with previous suggestions.
Inspect the steer axle closely - have seen them bent with hydraulic jacks
and clamps in an attempt to regain wheel alignment. Saw one almost
sheared and distorted in this way. Cruel what was done at times.
Might be quicker and cheaper to contact Ken Dennis, the Truck Whisperer
at Benalla. Worth looking at his U Tubes on steering, alignment etc.
I have no connection or first hand experience, but wish this service was
available in 1990, had to try to steer a prime mover with serious problems.
Heaps spent on laser alignments, trailer alignment, turntable position etc.
He does travel the country providing his services. Good luck with it. Paul.
- Thank you received: 599
2 years 1 month ago #233238
Replied by 180wannabe on topic Strange tyre wear - please help
About 12 months ago a bloke told me that running radial tyres on the steer of a truck not set up for radials will wear the tyres exactly as described/shown.
2 years 1 month ago #233248
by V8Ian
Replied by V8Ian on topic Strange tyre wear - please help
Check that the rear axle is at 90⁰ to the chassis. A broken centre bolt can cause this problem, if not on air. Look at all bushes etc., the problem is likely in the back axle(s).
2 years 1 month ago - 2 years 1 month ago #233249
Replied by asw120 on topic Strange tyre wear - please help
Looks like what lots of roundabouts does.
Perhaps oddly, they don't look at all feathered. Bad toe setting will feather the tread.
I'll be interested to follow this one; my dad's bus won't go in a straight line.
Last edit: 2 years 1 month ago by asw120.
2 years 1 month ago #233252
Replied by cobbadog on topic Strange tyre wear - please help
A proper wheel alignment is high on the list of things to do. Check all steering and rear joints and bushes for wear. So many things can cause the problem from toe in, camber not adjusted to rear being out of square even doing tight "U" turns a lot. The outcome of the alignment always depends on the person doing the job. If they just want your money and do next to nothing then keep away. Get recomendations of people that know what they are doing and one has been suggested already and I thought by now a few shops would have been named. The closest one to me that I could trust is back down in Sydney at Narellan. The 2 local guys dont have a clue or the gear.
When I worked at BFT in town they started doing laser alignments and had a mobile service. We had some customers that had bad tyre wear everywhere and was sorted out. The system they used was the use of tapered wedges and looking at the specs at the beginning and again at the end this made a huge improvement and then aligned all the axles front to rear with great results. By the time I left that mob the mobile ser4vice was no longer offered and only done at Silverwater branch for what ever reason.
Do a thorough inspection of everything underneath then track down a good alignment.
Time to create page: 0.519 seconds
