- Thank you received: 542
Strange tyre wear - please help
2 years 1 week ago #233257
Replied by Blackduck59 on topic Strange tyre wear - please help
Those tyres also look underinflated, that maybe aggravating the alignment issues.
2 years 1 week ago #233262
by ashmenz0
Replied by ashmenz0 on topic Strange tyre wear - please help
Blackduck59
What pressure do you suggest I run?
2 years 1 week ago #233263
by ashmenz0
Thanks heaps guys
I did a quick (rough) measure with a tape and found the passenger side to be around 30mm longer between the axles than the drivers side. Looks like I’ve got some work to do.
2 years 1 week ago #233264
by jeffo
Replied by jeffo on topic Strange tyre wear - please help
Weird tyre wear is typically a caster problem, will need specialist gear to diagnose properly.
Worn shackle pins or broken centre bolt can cause front to rear axle dimensions to differ so you’ll have to check all suspension components before you call on a mobile wheel alignment bloke.
Worn kingpins or loose wheel bearings can also cause strange wear but you would have checked those at annual machinery inspections.
Caster on leaf spring/axle setups is corrected by fitting tapered wedges between axle and spring.
Very common job.
Very common job.
2 years 1 week ago #233269
Replied by JOHN.K. on topic Strange tyre wear - please help
If its an airbg Denning,Id have a good look at the front suspension ,as its trailing arms fabricated from light wall tube.........cracks in the chassis mounting of the trailing arms were pretty common.......generally a crack joining the two pivot points.............the moun ting of the fabrication to the Rockwell axle may also be loose.
2 years 1 week ago #233275
Replied by Swishy on topic Strange tyre wear - please help
FWIW
akso look @ where the spring sits on the saddle @ the axle
Look for movement ... as in a fine line and not sealed with dirt or rust etc
Check all chassis bolts th@ hold the suspension
- Thank you received: 4632
2 years 1 week ago #233281
Replied by Mrsmackpaul on topic Strange tyre wear - please help
Dunno if this will be of any help, it is for Mack trucks if the link works
www.google.com/url?sa=t&source=web&rct=j...BmBG5ZDhO8dUnxe2FVRs
Should open a pdf but who knows ?
Even though it isnt quite right it ahould give you some really good indications of what is or isnt wrong and hopefully take a lot of the guess work out
2 years 1 week ago #233282
by PaulFH
Replied by PaulFH on topic Strange tyre wear - please help
AshmenzO - His business involves correcting power steering faults, which give rise to
many tracking problems, including abnormal steer tyre wear.
Operators spend heaps on other corrective measures, often without result.
Worth viewing some of their U-Tubes if only for information. Paul.
Time to create page: 0.634 seconds
