- Thank you received: 49
Strange tyre wear - please help
1 year 10 months ago #236062
by ashmenz0
Replied by ashmenz0 on topic Strange tyre wear - please help
Hi Hayseed
I'm very interested in getting to the bottom of it too.
Ash
Ash
1 year 9 months ago #237506
by ashmenz0
Finally got a wheel alignment on the old girl.
Turns out was toe out about 1 degree, now set to 1 degree toe in.
Back axle was out 6.4 degrees, now 3.6 as this was "as much as he could get without breaking something".
King pins need attention but nothing too drastic either.
He said the main issue was the tyre quality. They are out of round which was very evident. When spun the gap to the ground changed by about 6mm. No more "Triangle" brand tyres for me. Now looking for a good quality 10.00 x 20 steer tyre.
I just need to forget the different distance between the axles. It will be forever a mystery.
1 year 9 months ago #237507
Replied by hayseed on topic Strange tyre wear - please help
Thanks for the update.. & I'm glad you have It on the way of being sorted...!!
I'm surprised about this ^^^^ I've had an Extremely Good Run out of Traingle Tyres over the years (though Mine have being ALL Tubeless). I've even had Cases that had been Recapped twice without any Issues..
No more "Triangle" brand tyres for me..
1 year 9 months ago #237508
by ashmenz0
Cheers Hayseed
Maybe it's an issue with the tube style. Not sure but alignment guy was not a fan.
Do you have them on the steer?
1 year 9 months ago #237509
Replied by jon_d on topic Strange tyre wear - please help
Ash.
Good news on the alignment.
Have a look at these. haulmaxtyres.com.au/product/att202/
I have them on the back. And will fit them to the from when needed. (btw, I run almost zero toe on the bus.)
1 year 9 months ago #237510
by overnite
Replied by overnite on topic Strange tyre wear - please help
I was always under the impression zero toe in for radials.
1 year 9 months ago #237512
by ashmenz0
Hi Jon_d
What sort of bus do you have?
1 year 9 months ago #237513
by ashmenz0
Not sure about that mate.
Alignment guy has been doing it for years and was absolutely certain.
1 year 9 months ago #237514
On the bus, the fronts are Michelin radials. It used to wander all over the place until I went zero and replaced the reasonably tight tie rod ends.
The manual says Parallel to 0.06inch toe-in (at the wheel centre height) for rags.
Time to create page: 0.557 seconds
