- Thank you received: 13
Inter C1600 281 eng
2 years 5 days ago #234245
by Bimbadeen
Inter C1600 281 eng was created by Bimbadeen
Have inter C 1600 with 281 eng single speed 6.16 diff.
At 50mph eng revs 2800
At 55mph eng revs 3200
Would like to reduce revs at 50-55 mph.
Any suggestions
Thank you,
Maurice.
Any suggestions
Thank you,
Maurice.
- Thank you received: 599
2 years 5 days ago #234247
Replied by 180wannabe on topic Inter C1600 281 eng
That diff ratio makes me ask, is the truck a 4x4?
Brett.
Brett.
2 years 5 days ago #234250
Replied by hayseed on topic Inter C1600 281 eng
I thought C1600's had a 2 speed Diff..??
Maurice, Back when they were Brand new the speed limit for Trucks was 50MPH, hence the gearing..!
You're either going to put a 5 speed Overdrive Box in It, Or change the Diff Ratio..
But remember, making it go faster Also makes it harder to Stop..!!
The following user(s) said Thank You: Tassie Dan
2 years 5 days ago #234251
Replied by asw120 on topic Inter C1600 281 eng
What tyre size? 7.50x20? Could maybe go up to 8.25. I don't know what other diff ratios there are for that size axle. Bearing in mind, if you gear up very much, it won't pull a load.
2 years 5 days ago #234252
by Bimbadeen
Replied by Bimbadeen on topic Inter C1600 281 eng
Since U have owned truck it has been 4 X 2 with diff 6.16
2 years 5 days ago #234253
by Bimbadeen
Yes the C1600 did have 2 speed diff as an option
2 years 5 days ago #234254
by Bimbadeen
Not wanting to go faster but 50 -55 with few less revs
M
M
2 years 5 days ago #234255
by Bimbadeen
Already running 8.25 tyres and yes understand about reducing pwr with too high a diff ratio
2 years 5 days ago #234256
Running 9.00 x 20 tyres shouldn't be a problem to pick up a bit of speed. I'm guessing your truck would have 5 stud disc wheels? I doubt you will find any faster diff from that model/era. You might find a faster ratio diff from a 410/510/610 Acco, but i'm not sure on pumpkin/housing compatibility, or swapping the whole diff as i imagine the 410/510 Acco diffs would have smaller brakes. I have a fast (5.41/7.44:1) 2 speed Rockwell in a 1730a Acco, but that has spider hubs.
The other option is to find and fit a T34 overdrive gearbox. Expensive gearbox to buy if you can find one, and a bit of work to make fit.
2 years 5 days ago - 2 years 5 days ago #234258
I've got a chart (somewhere) that tells you how many Revs per Mile/Km each size Tyre does.. But Can't Find It...(& Google is No help)
From memory, If you step up to 10..0x20 Tyres you will either go 10-12% faster or your Revs drop 10-12%...BISTBC
Last edit: 2 years 5 days ago by hayseed.
