Updated 28th July.
Welcome, Guest
TOPIC:
Portable Disiel Heater 08 Jun 2022 20:35 #235841
  • jon_d
  • Away
  • Thank you received: 213
Have a 5kw unit in the bus. Works like a charm.
There are 3 grades available. European models. about $2k Top End Chinese about $700. Ebay Chinese about $180
I have the top end Chinese unit. The quality is noticeably better than the ebay units. Things like teflon wires, heavier steel, SS furnace fittings and castings. Having said that there are lots and lots ebays fitted in vans and things. Parts are not a problem. All on ebay or aliexpress.
The hardest thing with the cheapies is understanding the manaul. Installation is all the same.
The portable heaters are the same but in a case. You just need to ensure that the exhaust and inlet are ducted safely away. Also, they need a seperate power supply too.
Source: ebay or Aliexpress.
Just one example. www.aliexpress.com/item/4000258352504.html?
And, the most important thing to do is replace the fuel line joiners with proper 3/16 fuel line, The Chinese stuff is single wall rubber crap and it perishes quickly.
The following user(s) said Thank You: Sarge :-X, cobbadog, Lang
Last edit: by jon_d.
Portable Disiel Heater 18 Jun 2022 15:10 #236130
  • geoffb
  • geoffb's Avatar Topic Author
  • Thank you received: 92
Bought one and can't under stand the instructions at all
Portable Disiel Heater 18 Jun 2022 15:23 #236131
  • Mrsmackpaul
  • Mrsmackpaul's Avatar
  • Thank you received: 2623
Take a photo and bung it up for us to look at and maybe we can decipher it
Portable Disiel Heater 18 Jun 2022 15:44 #236132
  • jon_d
  • Away
The best thing to do is search Chinese Diesel Heaters on youtube.
There is a plethora of videos.
Which model did you buy? (link?)
Portable Disiel Heater 19 Jun 2022 09:52 #236169
  • geoffb
This is the unit can get it to start but get the remote to pair or adjust the fan etc
Portable Disiel Heater 19 Jun 2022 10:37 #236170
  • Mrsmackpaul
Have you tried contacting the supplier?
Most get back to me if I have a drama
Portable Disiel Heater 19 Jun 2022 11:57 #236171
  • hayseed
  • hayseed's Avatar
  • Thank you received: 1438
你需要一个翻译伴侣。
Nǐ xūyào yīgè fānyì bànlǚ.
Portable Disiel Heater 19 Jun 2022 16:17 #236184
  • jon_d
  • Away
Geoff,
The general sequence is:
Turn on.
Enable heat mode. - glow starts.
When hot for ignition enought - pump starts. (ticking)
Fan - starts when furnace warms.
Glow stops when hot enough to sustain ignition
Fan speeds up.
Drops into auto or manual model
You need to power first and then enable heater, then start the heat cycle. There are anunciators for each stage. (glow/pump/fan etc)
This video may help.
Portable Disiel Heater 19 Jun 2022 16:40 #236185
  • roKWiz
  • roKWiz's Avatar
  • Thank you received: 284
Before even starting the heat cycle, you need to set the pump (click, click, click) to bring fuel up to the burner. (priming the pump) Once that is done, set the temp setting on the right side, up and down buttons and you good to go.
Good tip is before turning it off is temporarily turn the temp higher so the glow plug will burn off any residue, keeping the thing clean for the next time.
I installed one in our cabin and one in the motorhome. The larger cabin one is mounted externally under the floor while the MH one is install under a sofa.
They run on such a small amount of fuel. The cabin one I've been running every evening @ 23C for 5 hours for the past 2 weeks. It used 600mm of my own bio diesel mix.
Co2 detector is a must.
Heritage Stonemason
Last edit: by roKWiz.
Portable Disiel Heater 19 Jun 2022 20:14 #236189
  • Dodgeydude
  • Dodgeydude's Avatar
  • Thank you received: 75
I gather you just need to know how the remote works.
Last edit: by hayseed. Reason: rotated & inserted Pic.
Time to create page: 0.354 seconds
