- Thank you received: 839
Portable Disiel Heater
1 year 9 months ago - 1 year 9 months ago #236193
by BillyP
I used to be a truck driver,
on a good day i can remember
Replied by BillyP on topic Portable Disiel Heater
.Browny..........
We have had a Wabasto airtop 2000 (2kw ) in our van for about 10 years....no troubles at all......
Back then there was not much choice, it was about 1600 bucks for all the bits and i fitted it............
If yours is portable , i hope the exhaust is external, otherwise there might not be too much Browny around.....
Actually, a carbon monoxide detector should be mandatory with any combustion heater ,
especially in confined spaces.............We have one on the wall near the bed head............
One other thing , with the fuel tank on the unit, you have to be really careful when topping up the fuel,
otherwise you will be eating tea etc , and sniffing diesel at the same time...................
....................Billy...............
.Browny..........
Last edit: 1 year 9 months ago by BillyP.
1 year 9 months ago #236199
Replied by Swishy on topic Portable Disiel Heater
- Thank you received: 313
1 year 9 months ago #236200
by Inter-Action
Replied by Inter-Action on topic Portable Disiel Heater
I bought one of the Chinese 5 kw units for the van. Thought i would give it a run on the bench before installing. Filled the diesel tank , and as i was about to connect battery and give it a run , a pool of diesel appeared on the bench and just kept getting bigger. Quick as i could removed the cabinet
and low and behold . Some "digbat" had put the wrong length screw in the bottom of the cabinet right through the fuel tank. Removed the tank , welded
it up , refitted tank , refilled , connected everything and all appears ok. No need to think what might have happened, had i installed it in the van and hit
the start button. Could have got a bit ugly , with the van parked under the patio of the house!!!!!!!!!!!!!!
1 year 9 months ago #236224
Replied by geoffb on topic Portable Disiel Heater
Thanks for all the guidance and suggestions
Looked at that Youtube and was most help full change the the battery in the remote ( Made a difference )
Have been bench testing all seems good
- Thank you received: 4694
1 year 9 months ago #236247
Replied by Mrsmackpaul on topic Portable Disiel Heater
So this means the diesel heater had a electrical problem
As the saying goes "erection problem? Call a erectrician" :dry: :lol: :lol: :lol:
1 year 9 months ago #236276
Sparky Paul you are correct
1 year 9 months ago #236304
So does this make it a hybrid heater ????
