We all know this basic stuff below but I can't figure out what the extra gear does on the new pump. In an air compressor gradually increasing pressure cylinders build on the incoming pressure but liquid is incompressible so no matter how many gears there are there can be no pressure increase - positive displacement - oil in = oil out. Has it just got something to do with sharing the load over an extra gear to reduce stress and wear on the shafts etc? That is it does nothing but make the pump stronger and longer life??
Oil pumps
Most oil pumps are driven directly by the crankshaft or camshaft.
All oil pumps are called positive displacement pumps - the amount of oil that leaves is the same as that enters. In other words, the pump moves oil from one side, to the other. This can be contrasted with a coolant pump, for example, which tries to move water but will not do so if the pressure is too great on one side.
As engine RPM increases, the pump turns faster and more oil is pumped. This is convenient because at higher engine speeds lubcrication and cooling requires a greater flow of oil.
A note on oil pressure
It is important to note that oil pressure is not produced by the oil pump. The oil pressure is caused by restrictions to the flow of oil - through narrow passageways, jet nozzles, and tight bearing clearances. If we simply connected a pipe to the outlet side of the oil pump and allowed it to discharge back into the sump, then there would be no oil pressure - the oil could flow unrestricted.
Knowing this, it’s now clear why worn bearings (particularly main bearings) would lead to a loss of oil pressure: the clearance in these bearings is now larger, and the oil’s flow is less restricted.
