Updated 28th July.
Welcome, Guest
  • Page:
  • 1
TOPIC:
roadworthy v's oil leak 05 Jul 2022 11:08 #236841
  • Bimbadeen
  • Thank you received: 3
How much of an oil leak would cause a knock back for a Road Worthy Certificate ?
Thank you for any help
Maurice.
roadworthy v's oil leak 05 Jul 2022 11:09 #236842
  • asw120
  • asw120's Avatar
  • Away
  • Thank you received: 559
Have been told if it drips while he's looking at it, it fails.
I usually stop a bit sort of the inspector's place to wipe the sump.
Jarrod
roadworthy v's oil leak 05 Jul 2022 11:27 #236843
  • mammoth
  • Thank you received: 533
especially if the drip goes down the back of his neck while he is in the pit under it, ha ha
The following user(s) said Thank You: cobbadog, asw120
roadworthy v's oil leak 05 Jul 2022 11:45 #236844
  • Vic Rhodes
  • Thank you received: 37
The following user(s) said Thank You: PaulFH, asw120
roadworthy v's oil leak 05 Jul 2022 12:52 #236848
  • hayseed
  • hayseed's Avatar
  • Thank you received: 1428
Maurice, From My experience, It depends on a couple of factors.
A ) The mood of the Bloke doing the inspection.
B ) The general condition & presentation of the rest of the Truck.
I Have seen on more than one occasion, where Blokes have rigged up a jam Tin to catch the Drip. & avoid dripping onto either the exhaust or Ground .
Which means they can't ping you as per the Link Vic has put up..!!
But Again, this depends on the Mood of the Bloke doing It..!!
The following user(s) said Thank You: cobbadog, ianoz
Last edit: by hayseed.
  • Page:
  • 1
Time to create page: 0.237 seconds
