- Thank you received: 1695
Atkinson cab
1 year 8 months ago #238065
by xspanrman
Replied by xspanrman on topic Atkinson cab
1 year 8 months ago #238066
Replied by Lang on topic Atkinson cab
There is every possibility this may be the very truck. I thought the paint was just red primer but it could well be faded PMG red? Something for Rex to look at with a bit of sandpaper.
The following user(s) said Thank You: xspanrman
1 year 8 months ago #238095
Replied by mammoth on topic Atkinson cab
For the sleuths; here is the link to Thornycroft chassis lists, up to 1956 which might just miss Rex's example.
collections.hampshireculture.org.uk/topi...ft-vehicle-registers
I think Rex's three axle Trusty would be an RF with 100hp NR6 engine If you know build date or chassis no it can be nailed.
Later versions had the 'modern' QR6 engine (as fitted to Ron Toy's Mastiff)
1 year 8 months ago - 1 year 8 months ago #238098
Replied by hayseed on topic Atkinson cab
Here is Hamish's reply to My Question regarding the Cab Mrsmack..
Hayseed, it's an Autolifts cab made by Autolifts & Engineering Co. of Blackburn, England. These cabs were also fitted to 1950s Albions as well. This is a 1955 Albion Claymore FT27 model in the Bill Richardson collection in N.Z. with the same type of cab. Obviously the lower part is different between the Atkinson and Albion, but the top half and windows are the same.
Last edit: 1 year 8 months ago by hayseed.
The following user(s) said Thank You: 180wannabe, Mrsmackpaul
- Mrsmackpaul
- Thank you received: 4707
1 year 8 months ago #238109
Replied by Mrsmackpaul on topic Atkinson cab
Thanks Seed
Im thinking it has been up dated in looks with some Thornycroft parts grafted on there
Tah muchly to all who helped, I'll pas the details on
1 year 8 months ago #238112
The Bill Richardson Albion has an Autolifts cab as previously noted, however I can't see that this or part of it is the same as the Atkinson cab. For one thing the Atki has sharp corners to the doors whereas the defining feature of Autolifts export cab was rounded corners to the doors.
Time to create page: 0.450 seconds
