- Thank you received: 4404
Lorrys' Tray Clean Up
3 years 4 months ago #238361
Lorrys' Tray Clean Up was created by cobbadog
Yep, I haven't bothered you lot for a while about Lorrys' so here is the latest progress. The front load board is now in high gloss 'Delicious Red' by Killrust. The inside of one of the gates is also now red. The light board for the top of the load board is high gloss White and ready to be fitted back on tomorrow I hope. The little bench is also painted and ready to go back on but I might put one last coat of White on it first.
I need to make a start on the back end and ramps by sanding them back to bare metal and make it ready for that Red Oxide metal prime. I must say that this Wattle red Oxide is a water based paint and is exceptionally good and easy to use. Before I used a product by Selleys which I could not fault but has been removed from the market and finally found a replacement for that one, whose name escapes me.
I don't think I will have it all finished in time for the Rusty Iron Rally but will try. At least it will look as if we love him and you can see it is heading in the right direction, looking decent again. Trucker across the road said I won't need any flashing lights ever with this red.
3 years 4 months ago #238388
Replied by cobbadog on topic Lorrys' Tray Clean Up
- Thank you received: 7731
3 years 4 months ago #238394
Replied by Mrsmackpaul on topic Lorrys' Tray Clean Up
Dunno if you have had the clearance lights on the hurdle before
I have and found them to make it impossible to see out the mirrors at night
Dunno if you need them on the hurdle or not, guessing not as semi trailers dont have them on the hurdle only under the tray
Looking very red
Looking very red
3 years 3 months ago #238404
Hi Paul, I have only driven Lorry twice of a night and they never gave any grief with the light hitting the mirrors. As for legality, last time I checked they had to be up top to denote the height as well as width. Mind you I have never gone back to read the latest set of regs but it is as it was built way back when so I kept them that way.
3 years 3 months ago #238406
Replied by mammoth on topic Lorrys' Tray Clean Up
Time for Vic Rhodes to chime in.....
Had similar issue with marker lights at night so now that we have physicly smaller LED's they get positioned inside the coaming rail and width markers are on the front side of the mirrors.
3 years 3 months ago #238508
Kicking myself in the arse today. I never got to put the gloss on the side until after lunch yesterday. Got up this morning and there was a heavy fog and now the gloss is flat as a fart. So much for trying to get a bit more done so it is finished for the Rally.
Anyway I managed to get the 2nd ramp ground back but then forgot about the bar that holds the ramp up, so this is a tomorrow job. Got the top and both sides of the ramp in primer at least. Hopefully tomorrow the underside can be primed as a slight bit of rain is predicted going by my weather woman named Dee.
3 years 3 months ago - 3 years 3 months ago #238510
Replied by Lang on topic Lorrys' Tray Clean Up
This is a handy ADR lighting reference
www.narva.com.au/resources/adr-13-00-lig...g-installation-guide
Here is the full ADR lighting section
www.legislation.gov.au/Details/F2017C01072
Last edit: 3 years 3 months ago by Lang.
3 years 3 months ago #238511
Good news is your not alone with paint problems, really is the wrong time of year be painting out doors I guess
Every time I have tried either showers of rain or fog like you have mentioned
But as I say to people "anyone can make it shiny but the real trick is to get it like this" as I'm pointing to my mess lol
Good work Cobba
Good work Cobba
3 years 3 months ago - 3 years 3 months ago #238519
So next chance I get another coat of GLOSS will go over the top.
Last edit: 3 years 3 months ago by cobbadog.
Time to create page: 0.320 seconds
