Acco 1710b window parts
2 years 9 months ago #239153 by MickM
Hi Guys ,
I’m working on getting the door windows working again on my 1710b. Any idea where to get rubber kits and also the bottom steel piece that fits to the bottom of the window that the rollers run along.
Cheers Mick
2 years 9 months ago - 2 years 9 months ago #239161 by Lang
Replied by Lang on topic Acco 1710b window parts
Mick
I had that problem with my Mack. Solved it by going to the wreckers and buying two old Holden windows. Most older cars had a very close match. The little runner track section of similar shape to yours can be removed by just drilling the couple of spot welds.
I glued the new section to the bottom of the truck window frame with two pack SIKA. there is not much pressure to lower the window and stress the glue and all the heavy lifting up force is against the frame
Last edit: 2 years 9 months ago by Lang.
2 years 9 months ago #239165 by hayseed
Replied by hayseed on topic Acco 1710b window parts
Clark Rubber will have the Rubbers.. Just take the Old ones with you so you can match them Up.
Also; Have you Tried IVECO?? It's surprising What they can supply on Old Acco's..
2 years 9 months ago #239173 by mammoth
Replied by mammoth on topic Acco 1710b window parts
Fleet Parts in Toowoomba is your one stop shop for International
Time to create page: 0.319 seconds
