13 speed OD gearbox
3 years 4 months ago #242012 by Bimbadeen
Could a 13 speed OD Eaton Fuller gearbox fit behind 1981 Inter 1910 C Acco with 392 engine.???
Maurice.
3 years 4 months ago #242013 by JOHN.K.
Replied by JOHN.K. on topic 13 speed OD gearbox
Yes a RT/O 6613 ,small 13 ......actually factory fitted behind the 392 ......but using a quite rare IH made adaptor housing,one of which I have not seen in 40 years.
3 years 4 months ago #242016 by hayseed
Replied by hayseed on topic 13 speed OD gearbox
Maurice, Doesn't your old ACCO already have a Roadranger Fitted..??
3 years 4 months ago #242034 by Bimbadeen
Replied by Bimbadeen on topic 13 speed OD gearbox
Hi Hayseed my Acco does have a 10 Speed roadranger but having driven trucks often with a 13 OD and really think they r one of the best combos around !!!
3 years 4 months ago #242035 by Bimbadeen
Thanks John K
Maurice
3 years 4 months ago #242036 by hayseed
As John ahs pointed out RTO613 will fit. You will have to shorten the tailshaft & change the Gear knob over..!
3 years 4 months ago #242037 by 180wannabe
Replied by 180wannabe on topic 13 speed OD gearbox
I tend to think you would achieve the same on road drive-ability (same top 5 ratios) with an RTO-610 as you would with an RTO-613, (you just wouldn't have the 3 low creeper gears), and an RTO-610 might be easier to find.
Either way, it is my understanding that all gear changes with either box will be a stick change. As far as i know the 600 series 13 speed boxes don't split the top 4 gears like a 900 series, the 600 series have 3 gears in LOW, 5 gears in INTERMEDIATE, and 5 gears in HIGH, every gear being a stick change. Someone please correct me if i have got that wrong.
I have an idea i read somewhere once that the 6613 is an updated version of the 613, i think something to do with differently cut gears, but again happy to be corrected.
Brett.
The following user(s) said Thank You: hayseed
3 years 4 months ago #242038 by V8Ian
Replied by V8Ian on topic 13 speed OD gearbox
Brett.
My memory says five gears in low, four in intermediate and four in high/direct.
3 years 4 months ago #242041 by werkhorse
Replied by werkhorse on topic 13 speed OD gearbox
Brett is correct ...3,5,5
But the best way to drive the little 13 speeds is the same as a 15 speed
All 5 in Low .... Then 4th and 5th in Intermediate.... Then all 5 in Direct
The following user(s) said Thank You: hayseed, 180wannabe, Kav
3 years 4 months ago #242042 by Swishy
Replied by Swishy on topic 13 speed OD gearbox
The following user(s) said Thank You: hayseed, 180wannabe, cobbadog
Time to create page: 0.266 seconds
