Info Please
7 months 3 weeks ago #256224
Info Please was created by Swishy
We are rewiring a trailer rear bumper
and we need to join wires
problem with LED lights each one needs a earth wire
I can remember Fruehauf trailers have wire joiners that were
a tapered insulated tightly wound spring
guessing about 30mm (1.1/4)Long x 20mm (3/4 Diameter)
the idea being you bared back the plastic on the wire ends and twist all the wires together to a point
then twisted them into the spring joiner
I need to kno the name of these dodadds and availability
Thanx in Advance
Thanx in Advance
- Thank you received: 811
7 months 3 weeks ago #256226
Replied by 180wannabe on topic Info Please
Try "twist on wire connector".
Not quite sure if that is what you are looking for?
Brett.
Brett.
- Thank you received: 814
7 months 3 weeks ago #256227
by 77louie400
Replied by 77louie400 on topic Info Please
Swishy, the ones with the screws are BP connectors, short for blue point connectors, do a search and the screw on ones will probably come up, I am not a fan of either, I would use in line crimps or solder and heat shrink, unless of course you expect to be changing out smashed lights every other day, then I would use the ones with the screw.
7 months 3 weeks ago #256231
by V8Ian
Replied by V8Ian on topic Info Please
I know the ones you mean Swishy, they used to come in the crimp grab kits. Jaycar can probably help you. I reckon they're pretty dodgy, you could use eye or U crimp terminals and attach them to the lamp securing bolts.
7 months 3 weeks ago #256234
Replied by jon_d on topic Info Please
Something like these?
www.cabac.com.au/p/electrical-power-conn...-connectors/30-241ja
7 months 3 weeks ago - 7 months 3 weeks ago #256236
Replied by Swishy on topic Info Please
Brett
gudday m8
put me on a search with google
Tar muchly
https://t3.gstatic.com/shopping?q=tbn:ANd9GcQHwoWNAy2HX5meubLFRaNl0NPqO9W6ECwkiW3286N4rQuyATJ9yS1OQzYVIbDxd5vIwqocZWmGzVfnXj-E-tO_q9ubHBQCLiQrLAqiSlKkb7BSlxl5e_jT&usqp=CAs
https://www.cabac.com.au/media/catalog/product/3/0/30__45__241JA__primary_1.jpg?quality=80&fit=bounds&height=277&width=448Twister 341 Tan Wire Connector
Louie m80
We trying to keep away with screws aand crimp as both are not reliable after a few years
V8Ian
We made our own a few years back on different vehicles and trailers
thin cobveyor belt with small brass screws with a inch of thread and fir the wires with a soldered eye with brass nuts etc
too fiddly and a short in the circuit burnt the conveyer belt
JonD
U nailed it
not sure how many wires we can get in one of these
If we use all the earths =10 wires
thanx guys for your input
gudday m8
Tar muchly
Louie m80
V8Ian
JonD
U nailed it
Last edit: 7 months 3 weeks ago by Swishy.
The following user(s) said Thank You: 180wannabe, 77louie400
Time to create page: 0.241 seconds
