- Thank you received: 5907
Truck bellcrank rear suspensions
10 months 1 week ago #256802
by PaulFH
Replied by PaulFH on topic Truck bellcrank rear suspensions
Looking at LN700’s Ford Cargo diagram, the Benz setup was drive axle leading, with a beam bushed to the rear of that spring, rocker pivot on the chassis 40% towards a bush to the trailing end of the lazy axle spring. Looked awkward.
Might have been one of Pages conversions?
The following user(s) said Thank You: LN700
10 months 1 week ago #256803
Replied by JOHN.K. on topic Truck bellcrank rear suspensions
i think the TandemTrac suspension fitted to the ACCOT was 60/40 .......I know you could get a Ford D series with a 60 /40 Hendrickson lazy ............The Leyland suspension was more complicated ,as the front ends of the springs rose and fell too . Albions with the four spring were very common once ,most here know the RE29 Reiver .
10 months 1 week ago #256818
by roKWiz
Heritage Stonemason
Replied by roKWiz on topic Truck bellcrank rear suspensions
Heritage Stonemason
10 months 1 week ago #256837
by jeffo
I always liked the Leyland non reactive suspension.
Its only drawback was one end of the cranks and rods was above the chassis. Not a problem for a tray or tipper but no good for a turntable.
But some ingenious reversal of the cranks had them below top of chassis.
Lots of grease nipples compared to the single point 6-rod setup.
Replied by jeffo on topic Truck bellcrank rear suspensions
- Thank you received: 8051
10 months 1 week ago #256839
Replied by Mrsmackpaul on topic Truck bellcrank rear suspensions
Was Goth suspension like this, had rods and doohickies here and there
Don't know if they were adjustable ?
10 months 2 weeks ago #256853
by jeffo
Airbags were the finish for all this type of suspension.
I remember my first Freighter trailer had a crazy equalising beam arrangement that went from rear to rear of each spring set. Of course this meant the equaliser beam had to be mounted inboard of the springs inducing an eccentric load in its centre pivot bush. Special grease didn’t help much.
Then my Haulmarks had the “normal” equalising beam running from rear of front springs to front of rear springs. Dead simple.
My next Haulmark had a bell crank system, still running rear of front spring to front of rear springs. Gave no trouble, but to me that trailer didn’t corner as well as the older system.
Rare to see a trailer on springs these days unless it’s carting cattle. Those blokes like it simple.
10 months 1 week ago #256910
by werkhorse
Replied by werkhorse on topic Truck bellcrank rear suspensions
Yes Goth was another version of this type
Time to create page: 0.342 seconds
