My little Terrier
12 years 5 months ago #5426 by kenny-mopar
Replied by kenny-mopar on topic Re: My little Terrier
many moons ago i seen two other leyland trucks(boxers not Terriers) fitted with Pnut -P76 motors) ..although i doubt Leyland ever fitted them to anything larger than a "terrier" ?
12 years 5 months ago #5427 by Eddy
Replied by Eddy on topic Re: My little Terrier
Correct ... Terrier only
12 years 5 months ago - 12 years 5 months ago #5428 by The Moth
Replied by The Moth on topic Re: My little Terrier
Leyland offered the petrol V8 on the Boxer - with the Auto option no less - (As per their 1977 newspaper advertising at the time) - but I have no proof any were actually made.
www.hcvc.com.au/forum/YaBB.pl?num=1380448584
As I usually use Facebook , photo posting here is a pain as the ads are on the Facebook page. - I will try to "kick the bucket" again
Last edit: 12 years 5 months ago by jimbo51.
12 years 5 months ago #5429 by The Moth
both little sports cars now which one goes faster the virgin white or lemon yellow :D :D
The virgin(?) white one ....
yella is on 16s white is on 20s
White one'll do 120 or better, yella will redline at about 90 ;D
Hmm - I can get more revs out of the motor .. maybe the 7000rpm tacho is not as silly as it looks .. lol
12 years 5 months ago #5430 by Eddy
Info I have (from the former state manager) is that there was a stuff-up by the advertising company. Petty V8 was never intended for the heavier trucks, diesel engines only for them.
12 years 5 months ago - 12 years 5 months ago #5431 by Eddy
The main problem I found with either the Terrier or P76 V8's was their habit of cracking pistons if you pushed them too hard ...
:D ;D :D ;D :D ;D :D ;D :D ;D
really ????
You'll crack a piston in any engine if you "push it too hard" ... would that make it habitual? ::)
I know a bloke quite well who has a P76 V8 in an off road racer. Same engine for 18 years, changed rings and bearings twice, still original pistons.
I guess he's not pushing it "too hard" then ... ;)
Last edit: 12 years 5 months ago by Eddy.
12 years 5 months ago #5432 by Mrsmackpaul
Replied by Mrsmackpaul on topic Re: My little Terrier
Humes Plastics in Clayton had a Terrier with the V8 and auto which I got to drive now and again, it was no powerhouse that was for sure. The main problem I found with either the Terrier or P76 V8's was their habit of cracking pistons if you pushed them too hard, other than that they were pretty good.
I know what the problem is I have been known to have the same affliction I believe that correct term is "the nut behind the wheel syndrome" :D :D
seeya
12 years 5 months ago #5433 by ray
Replied by ray on topic Re: My little Terrier
I guess I must have pushed them a bit too hard then!!
12 years 5 months ago #5434 by kenny-mopar
& theres 2 P76s sitting in my carport
12 years 5 months ago #5435 by The Moth
Theres 5 P76's at my house ..
The original petrol P76 V8 motors did crack pistons and a common mod for the car was to use Holden 173 pistons but the Terrier had different low comp pistons (no better) and a mechanical governor in the rotor button that stopped the engine going much over 3000 rpm.. Later pistons cured the problems ..
Time to create page: 0.357 seconds
