Re: Chassis number locations -put them in here
12 years 3 months ago #72444
by Chocs
Chassis number locations -put them in here was created by Chocs
How about we make it easier for the next bloke...
What about keeping this thread for chassis number locations...
We have had the question asked many times...
i have just obtained a
and can't find the chassis number..Any clues??????
I'll start:
chocs
I'll start:
chocs
12 years 3 months ago - 12 years 3 months ago #72445
by Chocs
Replied by Chocs on topic Re: Chassis number locations -put them in here
1971 International 4070A Transtar
left hand chassis rail approximately 125mm (5")
forward of the rear spring hanger, on the front spring
chocs
chocs
12 years 3 months ago #72446
by Chocs
1990 International S line (SF2670)
Left hand chassis rail
app. 350mm (14") behind the front spring hanger
chocs
chocs
12 years 3 months ago #72447
Replied by on topic Re: Chassis number locations -put them in here
Good idea Chocs.
1979 International ACCO (I'd imagine most ACCOs are the same)
Passenger side chassis rail forward of the front spring hanger, on the front spring.
(See photo)
(See photo)
12 years 3 months ago #72448
Replied by bparo on topic Re: Chassis number locations -put them in here
AR series International Left front chassis rail
12 years 3 months ago #72449
by murranji
1979 mack r600 685 rs 1978 r700 797 rs
Replied by murranji on topic Re: Chassis number locations -put them in here
mack bogie drive rhs chassis behind front drive upto about 1982 . some are on the lh chassis near the the front spring mount. single drive can be either side front or near the drive rh side, i have found them on the side near the top or bottom flanges
12 years 3 months ago - 12 years 3 months ago #72450
On the Forward Control (F-series) Macks, the chassis number is also hidden on the chassis, underneath where the big cab support member, that runs over the top of the motor, is bolted.
You have to unbolt the cab support member to see it. This was an anti-theft measure by Mack.
12 years 3 months ago - 12 years 3 months ago #72451
peterbilt cabovers up to 1964 (at least the rh australian ones)...on the upper chassis flange just behind the cab mount leg on both rails which was meant to be covered by the pogo stick crossmember (anti theft measure ?)
cabovers from 1964 had the number, once again on both rails, stamped low and just forward of the front spring shackle bracket,
all conventional petes i have seen have had the number stamped high on the side of the rail, once again both sides, between the rear cab support bolts (six bolts each side) and also on the hood latch extrusion rails, as you lift the hood, looking down on the inside
12 years 3 months ago #72452
# 1 Tip from the
Replied by Swishy on topic Re: Chassis number locations -put them in here
# 1 Tip from the
12 years 3 months ago #72453
by jimbo51
Replied by jimbo51 on topic Re: Chassis number locations -put them in here
It was interesting walking around Sandown and looking at KW "chassis numbers" on rego labels (yes, I'm tragic).
Surprisingly there were a number with the same "chassis number"! Actually it was the part number of the chassis rail.
So it helps to know the format of the number you are looking for to avoid such mistakes.
Time to create page: 0.451 seconds
