245 hemi problems
12 years 9 months ago #79244 by Ed
245 hemi problems was created by Ed
HI
gee the old girl is testing me,
my DODGE 300 has the Hemi 245 dual fuel. with the 4 speed,
the old girl has been runing like a gem,
now the old girl is ideling rough and wont idle on petrol!! and has a rough run as it builds in the revs but once she revs over about 1500 rpm, it all seems good untill you come to a stop or slow down and go to take of again, the rough runing returns and it has no pulling power.
I have changed the plugs and a couple of the leads and moved the timing a little to c if this help but it doesnt seem to help.
does any one have any ideas for me to try?
(no vacum leaks I can find)
thanks
ed
12 years 9 months ago #79245 by kenny-mopar
Replied by kenny-mopar on topic Re: 245 hemi problems
maybe no vacuum leaks ..but most likely dried up carby components (gaskets etc) from lack of lubrication and the dryness of the lpg
12 years 9 months ago #79246 by discomack
Replied by discomack on topic Re: 245 hemi problems
Ed,check coil or Ballast resistor,lead from coil to dissy,run a hot wire from battery to positive side of coil and go for a drive ,if that improves it then the coil is the problem,if it still plays up get a new ballast resistor Hemi performance is a good place for these items also Billy who owns Hemi is a wizz when it comes to all things mopar
12 years 9 months ago #79247 by gilly
Replied by gilly on topic Re: 245 hemi problems
Ed,
Take the guess work out of the diagnosing, a vac gauge at least to check the mechanicals. Does it have 20in of vac at idle, if not, a mechanical issue is present. The best tool of all to diagnose beyond all reasonable doubt, a good quality exhaust gas analyser, works on all engines, regardless of size or what fuel, the old saying, what goes in, must come out, & that is where you will find what is going on. If the fuel delivery is correct at a Lambda of 1:00, anything to do with getting the fuel into the engine must be correct. A good quality gas bench will be able to then display the combustion efficiency & the wasted fuel fuel due to incomplete burn if it exists, eg, if it idles at a Lambda of 1:00, wasted Hc should be less than 250ppm. Incomplete burn will be caused by ignition or mechanical issues,& with the process of elimination, a vac gauge will guide you to a mechanical condition. Without a means of basic testing, start throwing parts at, you will eventually find the problem. Gas analysis---$40.00, Parts????
You decide,
Gilly
12 years 9 months ago - 12 years 9 months ago #79248 by Ed
Replied by Ed on topic Re: 245 hemi problems
thanks guys for the help,
after thinking about my current problems with the old girl I took some advice and done a pressure test on all cylinders and to my surprise this was the result
cylinder 1,2,5 and 6 were all with equal psi with a 1 or 2 pound difference
cylinder 3 and 4 were 0 psi,
so with i removed the head and,
( you guessed it as you read this you are saying to your self? )
"BLOWN Head Gasket" between cylinder 3 and 4, and yes it was.
now to order the parts and put the old girl back to being used as a daily driver.
thanks
ed
Last edit: 12 years 9 months ago by Ed.
Time to create page: 0.449 seconds
