- Thank you received: 42
ACCO power ??
Dont try this at home cos the the CCM of the V8 Butterbox was only about 30 ton. Noel Herrod went on to buy the big 10x6 Atkinson shown on the front cover of my book, which i think was the first tri drive truck in OZ.
I thought they were available by then, but obviously not. They must not have appeared, until the new, forward-mount-cab Butterboxes arrived.
The 1840's had a GCM of 56,000 lbs, no matter what powered them (due to the standard, round tube, 34,000lb back ends, most likely).
The 6V-53 powered F1800's were 70,000 lbs GCM (woo-hoo!! ) .. and the DCF-402's were 125,000 lbs GCW.
The 1950 and 2050 had the bigger 38,000 lb Rockwell square tube back ends, from memory, and they were probably rated at 70,000 lbs, same as the Jimmy-powered F1800's.
Regardless, you could never say any of the Butterboxes were a road train PM .. regardless of how much you thought of Inters ..
Have seen a Blue n Black Butter Box with sleeper
poke n around Melb with tri SemiTrailer
(Make mental note 2 self: Must grab pic of the beast)
would Imagine tiz just the Butterbox ACCO cab monted on sum respectable chassis
ButEyeDoSt&2BCorrected
[ch9787]
from memeroyi think he was towing a linfox trailer doing local. i have not seen him for a while now
I've got a copy of the Inter Sales Catalogue from 1969, but it doesn't list the V8 Cummins powered, ACCO 1950 or 2050's in the Butterbox .. only the 1840's (with the 6-354 & the 392) .. the F1800, and the DCF-400's and 402's.
The 6V-53 powered F1800's were 70,000 lbs GCM (woo-hoo!! ) .. and the DCF-402's were 125,000 lbs GCW. The 1950 and 2050 had the bigger 38,000 lb Rockwell square tube back ends, from memory, and they were probably rated at 70,000 lbs, same as the Jimmy-powered F1800's. Regardless, you could never say any of the Butterboxes were a road train PM .. regardless of how much you thought of Inters ..
Onetrack,
Have you got a scanner??? I would really like to see the sales catalogue! Ping me offline if you want my email address for sending it to!
Joe
Sarge :-X
